PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 [79] 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Evaporator replacement
  2. thermostat question
  3. Electric Fan Cooling Suggestions?
  4. ticking type noise
  5. wtf?not idling, speedo doesn't work, brake light on, abs light on, engine light on
  6. V6 to 340 swap
  7. 99r/t electrical problem
  8. Door dome light switch
  9. i need help with tranny
  10. CTM module
  11. Got my A/C back!!! WOO HOO!!!!
  12. new guy
  13. Interior light and door locks
  14. A/C Not Blowing Properly
  15. Cheap Headlamp Front BUmper Bar.?
  16. turbo
  17. 2nd gen POS
  18. AC Drain Plugged
  19. Need help for Ecu
  20. Potential 4.56 Gear Swap
  21. set of 4 R/T wheels FOR SALE SE michigan $500obo must sell
  22. instrument pannel out
  23. 5.2l Overheating
  24. How Much Difference Do Headers Make
  25. A/C and a few other things.
  26. Viper stripes
  27. Heater Control Head Doesn't Work When Outside Temp is "--"
  28. weak sauce tranny
  29. 02 3.9L Starting Problems
  30. Tranny swap
  31. Installed new shocks.
  32. Did anyone ever jump their Dak?
  33. "Low Wash" light stays on :- (
  34. Question about replacing light bulb,..
  35. Speed Sensor Trouble
  36. V6 Headers?
  37. Grease Fittings?
  38. More Torque...
  39. Question you 2nd gen'ers
  40. worst day of my life
  41. Soon-to-be Dakota owner, advice?
  42. Subwoofer Box under Ext Cab back seats.
  43. cold air intake, newb question
  44. 45RFE Cooler Lines
  45. Horn quit working
  46. wierd humming noise at highway speeds
  47. Volume guard?
  48. Initiation
  49. pop or thump comming off throttle...
  50. 5.9 needed
  51. Need Help
  52. Check engine light on. Need to reset.
  53. kinda new and have a questions about my truck
  54. super 40 series delta flow
  55. vibration in the dash
  56. Luminics?
  57. Anyone got an extra lug wrench?
  58. 04 With Flimsy Body Panels.
  59. It's too damn hot to be messing with a/c!
  60. outer tie rod ends
  61. K & N air intake for a 98 2.5L
  62. Work on your truck using PhotoShop!!
  63. i want a picture of a dakota r/t with 275/55/17 tires on it!!
  64. Used Performance PCM upgrade
  65. I Want 30 mpg and POWER :(
  66. out of control speedometer
  67. 4.7 won't idle
  68. slight problem...
  69. 2000 Dakota cruise control issue
  70. another tranny bites the dust
  71. speaker size
  72. Flowmaster 40 - Best Place?
  73. Dont let the CTDs win this month! Vote DAKs!!!!
  74. Nothing but problems...
  75. i want somthing thats hella powerfull!!!!
  76. VERY high idle
  77. Helix coil
  78. header brands
  79. delayed shifting 2nd to 3rd
  80. Does the fan clutch affect shifting?
  81. Inner Tie Rod ends
  82. 03 wheel question
  83. black window/door piece
  84. NV3500 Clunking
  85. Drop a Hemi in? Worth it?
  86. got my stripe on
  87. New dakota owner questions - need help!
  88. Rocker Arms?
  89. 2002 dakota abs light flashing
  90. automatic upgrades
  91. 02 Dak qc 4x4 FS
  92. lift kits for the Dakaota
  93. Door pillar vinal?
  94. Front end tool kit
  95. Rattle from Passenger Side Front
  96. Hitch thing
  97. fuel problem 99 dakota please help
  98. 02 Dakota tranny prob
  99. R/T Emblems, 6in x 3 - 3.5in in size
  100. Attempted Theft LOL
  101. when the trans temp light comes on
  102. ALL oils to synthetic, and Red Line Products
  103. no power
  104. fan question???
  105. I found the blower resistor on a 97 Dakota
  106. New here Updated with pics After Lift
  107. Upper and Lower Ball Joints
  108. Tranny fluid
  109. wheel question
  110. I have been away.
  111. Camper Shell
  112. Limited Slip Differential
  113. Mods
  114. I need people who have knowledge :).
  115. WTF
  116. Blower Resistor on a 97 Dakota
  117. Windows/locks/alarms
  118. 2001 4.7 thermostat???
  119. Powerstroke ?
  120. clicking/ticking noise while coming to a stop
  121. Well I'm impressed it almost lasted a week
  122. what minor upgrades can I do?
  123. Leaking...any advice?
  124. Anyone have a center console for sell in grey??
  125. R/T wheels on a 4x4
  126. Ticking Noise?
  127. MOVED: toasted a rice burner
  128. Air bags for my R/T?
  129. Spark Plugs ?
  130. Painted radiator?
  131. Odd sounding problem
  132. dynomax bullet
  133. Questions as usual
  134. rims
  135. Hooker Aerochamber! :D
  136. ZOOM ZOOM OOPS
  137. PCM Product Numbers!!!
  138. Governor pressure sensor
  139. Mods necessary to beat Hemi Ram??
  140. good bye!!!!
  141. vacuum leak
  142. Unkown sound and problem---HELP
  143. Running glasspacks?
  144. tb upgrade
  145. control arms
  146. Finally... :)
  147. anyone in CA know the answer?
  148. K&N Recall
  149. abs & brake light
  150. A/C Line Disconnect tool supplement
  151. low to no oil pressure
  152. New guy with 'old' Dakota Checking in...
  153. Unbelievable....
  154. crack in block
  155. 01 Dodge Dakota DTC question
  156. Monroe shocks for Daks?
  157. brake shoe question
  158. tranny in trouble
  159. Price of tranny fluid for 2000 3.9?
  160. joined the dakota family!
  161. just used lucas Power steering leaks stops !!!
  162. Overall Pain
  163. Electric fan stays on (dead battery)
  164. Actuators - 2001 Dakota Question
  165. A little help.please
  166. Tranny issues and leak.
  167. Got passed by my own kind...
  168. Tranny Shifting into 1st???
  169. EVAP Canister
  170. '01 Dakota engine running rough
  171. Anybody Towing Large Travel Trailers?
  172. Dakota R/T 1/4 mile times & modifications!!
  173. cracked hoses
  174. champion truck plug 4436/4071??
  175. Front End Noise - Please help
  176. Evap Control Valve ticking?
  177. Transmission acting weird, any thoughts?
  178. Door won't open
  179. Exhaust
  180. Damn Engine Codes. Hate 'em.
  181. Anybody have info on Harland Sharp 1.7 Roller Rockers?
  182. A question
  183. Transfer case fluid
  184. Bought Used 99
  185. ABS and brake light on
  186. Need Help, truck wouldn't start!!!!
  187. abs sensor it rear end and turn signal relay
  188. 2003 dodge warrenty
  189. durango question
  190. 4.10
  191. rough idle
  192. Replacement Radio
  193. The Sea Foam cloud
  194. Tranny Shifting Issues!
  195. Rusted Welds on Frame
  196. pics
  197. New pics
  198. Chrome door handles
  199. blinker/radio problem
  200. Opinions on this dak
  201. Exhaust falling off; need replacement
  202. Rough ride;looking for softer ride
  203. Replacing blower motor-how do find it and replace it?
  204. Installing Deck
  205. superchips group buy?
  206. 04 Dakota starting problem
  207. V6 3.9 good or bad?
  208. How can you tell if your dakota has a 5.9 or not??
  209. WA FS: 02 Dak quad cab
  210. Tires! What to buy?
  211. Exterior LEDs
  212. Neat noise coming from rear end
  213. Interchangeable PCMs?
  214. Squeaky Clutch Pedal
  215. Whining from rear end.
  216. 2003 DODGE DAKOTA EX. SPORT PLUS FOR SALE $8,500
  217. New R/T Pics
  218. a question about towing !
  219. Oil filter question
  220. A-pillar
  221. 2000 Quad Cab V6 For Sale in FL
  222. Hello i need your advices guys !
  223. How to find axel ratio
  224. '99 diff interchange
  225. Need a little help
  226. Trans Temp light
  227. Easiest way to remove nameplates
  228. Rack and Pinion leak????
  229. what options do i have?
  230. running lights
  231. time for some paint
  232. Loving all my mods 03 QC 4.7
  233. Hard to start
  234. 2003 Dodge Dakota Manual
  235. V6 3.9L acceleration?
  236. Good price for a dakota
  237. Time to Change Shocks
  238. Oil Preassure Question/Issue
  239. I have autocrossed
  240. thanks for your help guys!!!!!!!!!!!!!!
  241. can i have some help fast!!!
  242. 2000 dakota
  243. gears...locker...programmer!?!
  244. Supercharger on an R/T??
  245. HELP!!! PLZ HELP!!!
  246. Projector lights on ebay
  247. Shaker Hood
  248. Trading my M-1 4bbl for M-1 2bbl
  249. 3.9 transfer to 5.2 or 5.9?
  250. Anyone have unwanted air intake resonator? I will buy it $$$
