View Full Version : 2nd Gen Dakota Tech
- Which actuator motor? air our floor vent problem.
- High Idle upon Startup ??
- Piston Damage Question
- Steering Leak Question
- Radiator inlet and outlet sizes
- Starter dakota 99 or ignition switch
- Coolant reservoir leaking at lower seam, can it be patched?
- oil consumption
- Anybody ever seen this style hood before?
- running rough
- Code Question
- 3.9 air cleaner assembly
- Electric Window parts - 98 Dakota Sport
- Serious problems
- Projector Housings
- 98 Dakota wide wheels
- Dakota cranks but wont start
- Tiny Nano switch bulbs
- Crank sensor replacement gone wrong!!!
- Back flush oil pickup tube?
- Disappearing Antifreeze
- Structure dust cover removal
- 98 4x4 Dakota wheels and tires
- New Year, New Issue (Fuel?)
- stumped
- got 97 kota, need help
- dakota 2003 probleme
- 2004 dakota sport radio antenna
- 03 4.7 transmission overdrive issue
- 2001 Dakota Oil Pan Removal Frustration
- Performance Parts?
- Ignition Problems
- rockauto??? old garbage
- 99 Dakota will not start!!
- Dorman Intermediate Shaft
- driveshaft wont go into transfer case
- Nv-233 transfer case extension housing leak
- My Dakota shakes (?)
- 98 dakota no just died
- Size Of Brake Drums, 9" or 11" For A Quad Cab ?
- New member needs simple wiring help
- Electrical issue?
- 2" lift on a 2002 2wd (with Pics!)
- Rear o2 sensor wire diagram..
- 2003 Dodge Dakota low beams and windshield wipers not working
- Strange brake pedal
- troublesome electrical problem
- Front suspension creaking
- 408 Stroker in 01 Motorsports Edition Dakota
- Popping in steering
- some more help please....
- head Light relay limiter?
- heater or ac problems under load
- 5.2/5.9 wiring needed to run motor?
- Bucket seat swap
- Tire Chains
- 2003 4.7 exhaust stud
- power fall off
- superchips question
- Miss fire
- 2002 4.7 Dakota 4x4
- any help///
- 2003 Dakota Brake Job
- Power Window stutters when going up - what does that mean?
- grille guard brand
- Finally.... ball joints
- 1998 Dodge Dakota Console help
- Idle issue
- Rough idle
- 03 quad cab stock radio
- Best aftermarket shocks & Tires ?
- exhaust pipe size
- LED interior lights
- Advice needed on Swap
- 2004 Dakota grinding pump noise, revs fluctuating...
- Fan stays on after key turned off
- Heat/AC Temp weirdness
- fan belt keeps wearing
- HELP Mechanic Replaced 4x4 Coupler??? '02 Sport
- New Member- Tire Question
- This may sound off but : > )
- New Member - Question about tires.
- 97 Sport 3.9 Makes my head Spin
- TCM swap
- Oil Pressor Issue
- 2000 - 200,000 mile review
- Replacing rear axle assembly. What can/can't I do?
- 2000 Dakota cold start problems
- How Often Do You Change Fuel Filter
- hi/lo headlight beams issue
- Heater blower issue
- suspension lift
- 98 Base model 4 cyl, No Tail lights or dash lights
- Help with 4 wheel drive
- Swap 2003 3.9 engine into a 2004 3.7?
- American Racing wheels question?
- ABS Brake Problem
- Noise when changing HVAC mode
- NV3500 or NV3550?
- What to replace while Dash is out?
- Gear indicator flashing all gears
- Can i Swap 3.9v6 Dakota automatic to Manual Transmision
- Master Cylinder issue...
- What sensor is this?
- Dodgeforum.com to the Rescue! Problem solved...
- Warm Start problem
- Oi pan leaking on new motor
- gauge lights goes on,like gas and ABS..
- 2001 4.7 stalling when cold
- pcm pinout question
- Transfer case swap, electric to manual
- Will PCM run standalone
- Ma girl ain't pullin !
- Help
- Need a pic please... help
- Dakota heater valve install
- Need help with vacuum hose layout...
- 2000 3.9 Auto Emissions
- axle nut size
- M1 Intake Turtle
- Tapping / Knocking / Clicking Sound
- fuel pump problem
- Speedo/Gauge cluster issues
- Question on Fuel
- 1999 3.9 to 1994 360 swap
- New Exhaust
- Catalytic converter vs clogged fuel filter
- Firing order
- Turn signals and wipers won't work help!
- It is fixed ( truck fuel pump )
- What Do You Do to Get a Few Extra Ponies?
- Key Fob Tester
- 2000 Dakota series of events after Check Gages
- 2002 Dakota 4.7 asking for feed back
- 1997 dodge dakota
- ABS light and Brake light
- Paint / Buffing
- Error P0432 Issue
- 2WD V6 oil pan removal
- LEDs
- Steering rack issue?
- Lost fuel delivery
- 2000 dakota rt
- Hub Assy Check
- 2003 Dakota wont move unless in 4H
- Distributor seal?
- Won't stay in gear
- power streering pump
- Brakes Not Working Properly
- Heater core flush
- No interior lights at all.
- Intermediate steering shaft - Lower U joint problem
- 2001 Dakota lower control arm bumper
- 2001 dodge dakota 4.7 Few questions
- Dash Lights fuse keeps blowing
- Crank sensor signal
- How much flow is supposed to go through the proportioning valve?
- changing fuel pump
- Noob with questions.. Went control and reciver hitch..
- high throttling while sitting idle
- Dakota overheating and dropping coolant
- electrical issue
- Need help with these codes...
- Bumpers
- Dumd question fuel tank size
- Door Compatibility
- turbo
- Power steering rack question
- Worn out converter?
- New Shoes
- Cluster Lights
- Fuel pump ,,, fuel pressure,,, IDK
- 2001 Dakota 5.9 liter get very hot
- 4.7 crew cab fuel pump
- No crank no start
- Oil Pump Questions
- power comes and goes below 2500 rpms
- Dodge prob
- No Spark issue has me stumped
- Blower Fan & A/C failed
- P1740 Transmission Code
- Front Driveshaft Question
- Tag light fuse?
- Need some advice on purchasing a dakota
- Blacking out stock wheels
- 97 Dakota
- '97 Dak ?s
- 2002 5.9L Quad cab broken shift cable
- Lifting
- A question about fan clutches
- 98 dakota pulling hard to right AFTER alignment
- radiator trans line out
- 4.7L Timing chains - any failures here?
- getting at rear freeze out plugs.
- 2002 Dodge Dakota
- 2004 Shackles
- New headlights and parking lights
- 2002 Dakota engine ticking/knocking HELP PLEASE
- Hard to start, surging idle, and bogging
- 97 nightmare
- 2002 3.9 clutch questions
- 2002 dakota exhaust
- Hood Scoop intake
- custom rear bumper
- Bumpy ride after new steering components, need some help...
- Dakota no start...please help!!
- Running rich bank 1
- Thoughts on these cheap ball joints
- 2003 Dakota SXT - Weight of Leer Cap
- ctm help
- wanting bigger tires on my dakota
- 3.9 engine swap
- 2000 dodge dakota 4.7
- Lost Key Fob
- Intermittent misfire on cylinder 1. Pulling my hair out.
- Dakota having issues starting - help!
- need help..have a bucking surge problem on 99 5.2 4x4
- question for the tuner guys...
- 46RE transmission mount replacement
- 99 dakota Front P side hard brake line
- Bad Fuel pump? Aftermarket?
- Replacing the clutch
- p1698 code,no bus,no working gauges,no start
- Project - Seats
- Trans service on a 3.9L Dakota 2000 model high mileage
- HVAC Control Panel Problem
- CTM Replacement
- Clutch pedal vibration
- Broken Valve Spring on a 4.7
- Compatible leaf springs
- Lifting without a lft kit
- 2004 dodge dakota rear brakes
- Lifting 97 dakota
- dodge runs bad
- Fuel temp sensor
- Dakota wont start
- 2001, 4.7 -- new engine/head blown
- 01 5.9 Quad cab. backfire and idle problems
- Rear differential
- cv shaft question
- Power Steering Connection Question
- ? rubber body plugs + grommets
- >>> HELP - Dakota Center Vents not working <<<
- Transmission Shifting
- Clunks & steering feedback after front-end rebuild?
- Oil pressure drop
- Truck Cap Fitment - Leer
- Need help with timing please
- axle seal ????
