PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 2001 Dodge Dakota 4.7 V8 Trans temp Light
  2. Dakota on tee beach?
  3. No reverse
  4. header recomendation?
  5. Lift on a 97 2wd
  6. Tail light and dash fuse
  7. 99 Dakota
  8. 1997 Dakota, hot rod motor swap help
  9. grinding noise. transmission?
  10. Shock diagnosis and replacement
  11. 2001 Dodge Dakota transmission pan
  12. Need a couple wiring diagrams
  13. Factory Rear Anti-Sway Bar?
  14. 2004 3.7 to 3.9 engine swap?
  15. First Time Throttle Body take down and clean
  16. School is Out!
  17. engine swap
  18. Ticking Noise
  19. A/C Issue
  20. Ctm problem
  21. 02 Dakota Bizarre electrical problems
  22. Help with power steering hose. Please.
  23. Need a help in my info. Please
  24. New Issues Cropping Up
  25. 04 Dakota Headlight Problem
  26. 97 Dakota NO BRAKE LIGHTS...HELP
  27. Anyone have these headlights?
  28. Noisy transfer case
  29. a/c issues
  30. Vent not changing locations
  31. Broken seatback ?? wondering if....
  32. 0645 code but no plugged in ?
  33. Cold air intake
  34. Cup Holder
  35. 2004 not shifting when floored or trying to pass you have to let off the gas
  36. AC will not cycle
  37. a.c. problems
  38. Price for dual exhuast?
  39. Mirror
  40. Installing an oooga horn
  41. coming over from the dark side! LOL
  42. Greenhorn here
  43. Problem with truck overheating
  44. Which would be the best traction device?
  45. Repairing parking brake
  46. o2 sensor pinout on a 1997 Dakota
  47. Dakota 4x4 front end problems
  48. Noisy clutch
  49. Brake question
  50. Start up prob
  51. power gains?
  52. tire width
  53. Can You Replace a 97 3.9L With a 96 3.9L?
  54. radio issue
  55. 3.9-5.2 swap! FIRST POST!
  56. Towing Question
  57. my new truck
  58. To Keep or Sell
  59. Squeal!
  60. DIY: 1997-2004 Dodge Dakota 2WD Wheel Bearing Replacement (VIDEO TUTORIAL)
  61. 31x10.5-15 bfg all terrains rub...?
  62. '03 4x4 SLT-Tranny Rebuild Costs?
  63. Aux power outlet fuse
  64. 2000 Dakota this thing is making noise
  65. Manual 1st Gear Bucking
  66. Dakota sounds like a diesel?
  67. painting exhaust headers
  68. Surging issues when cold?
  69. 2004 Dakota vapor canister
  70. Bedrug or Rubber Mat?
  71. HELP Brake Click
  72. Remember me? im backkkk...sorta
  73. 2002 Dakota 4x2 Clunk
  74. First gear slips
  75. First gear slips
  76. HELP!! Replacing hub/bearing and spline shaft is stuck
  77. 2000 Dodge Dakota EVS 2 Alarm
  78. Parking Brake Cable
  79. Mod suggestions
  80. Sudden loss of power and only shifts high RPMs
  81. Head lights won't work
  82. 4.7l troubles! help!
  83. sub enclosures
  84. 3.9to 5.2 swap
  85. Another mod list, I want to hear your two cents
  86. Speed sensor problem
  87. One Problem Fixed! 3 More Discovered
  88. Installing a Tach
  89. Anyone Bored?
  90. New Here Just Joined
  91. 1999 dodge dakota - accident help
  92. Transmission swaps
  93. 99 dakota 5.2 no oil pressue
  94. bed liner floor / write up move
  95. PLEASE HELP !!! Replaced everything....still intermitent miss real bad
  96. Rear Main Seal - Manual Trans
  97. Bumper lower on one side?
  98. Lift and 31s?
  99. Transmission-> OD not working and now no gears working
  100. new wheels and tires
  101. Occasional Misfire at Engine Start
  102. 99 dakota fog lamp issue
  103. loss of power
  104. 2000 Dakota RT 5.9 - ABS and Red Brake Light, speedo not working, p done
  105. I've never owned a Dodge before...
  106. 5.2 engine swap
  107. SAS Prep
  108. Better Tie Downs?
  109. torsion keys crank or leveling kit
  110. Transmission Shift Delay
  111. ultragage MAP reading?
  112. Easy Thermostat Change?
  113. in-hg vacuum at idle
  114. 44re shift kit issue
  115. door hinge
  116. a/c trouble
  117. timing chain or swap
  118. tuff country sx8000 shocks on dakota?
  119. Timing Cover Issues 97 Dakota 3.9L
  120. Another 46RE transmission question
  121. 98 dodge dakota upper control arm fabtech
  122. Help with AAMCO woes (valve body)
  123. Thrush Glasspack
  124. Leveling a 97 4X4
  125. 2002 dakota rear passenger window problem!!!
  126. valve cover help
  127. Cam Swap
  128. bump stops
  129. rear end noise
  130. Ticking in engine
  131. 3 MPG at 1200 RPM? Poor Gas Mileage
  132. 2004 Dodge Dakota Transmission Trouble
  133. Only Clicks when starting
  134. Help Me Locate a Clunk
  135. 2001 Dakota-shocks/power steering
  136. new dodge dakota. hey yall!!
  137. Trans slams back into first while driving and sometimes into reverse...
  138. Exhaust question
  139. Headlights go on and off on their own...
  140. 2000 Dakota 4wd code P1776 and 4wd issue
  141. Air Lift
  142. Transmission
  143. new dodge guy was old ford guy.
  144. New decals. I messed them up
  145. 8 or 10 ply??
  146. 4.7L auto trans question ??
  147. Transmission slip?
  148. P303 code comes and goes
  149. Dakota lift and 33s
  150. Oil Leak
  151. Any suggestions for Grill, Bumper, Headlights, etc?
  152. oil pressure problem
  153. Dual exhaust help
  154. 97 dakota sigle cab lifts? intakes? exhaust?
  155. 97 Dakota clunk in rear end
  156. Which trans-line feeds the cooling?
  157. New stereo time
  158. How do I check the coolant level?
  159. Engine idle inconsistency?
  160. 97 Dakota club cab sport towing capacity
  161. water pump bolts 5.2 liter question
  162. 2000 Dakota 4.7 manual to 5.9 swap
  163. Blinkers work even with key out
  164. 2002 dokota rt wheels
  165. Wheel Hub with ABS on no ABS Dak
  166. A turn for the worse(siezed spark plug)
  167. Gearing.
  168. Headlight Problems
  169. Wider Stance?
  170. Wheel size dilemma
  171. 2000 Dakota: elec fan on all time ?
  172. 1998 Dakota 4x4 right steering knuckle...
  173. New truck with clunking sound on turn
  174. Effects of 33" Tires?
  175. 97 dakota
  176. Similar tires
  177. 2001 Dodge Dakota Stereo Amp
  178. 2.5 to 5.9 swap?
  179. 2.5l Performance Chip?
  180. Cracked Block
  181. Gmc question
  182. Sold my truck, here's the new one
  183. I need help
  184. Stutters when taking off
  185. Observation on Aftermarket CAI for 4.7
  186. Hello hello
  187. Lift kit help??
  188. Body lift help????
  189. 2003 Dak Quad Cab 4.7 replacing oil pump
  190. Transmission line leak?
  191. Tires too big?
  192. 11.50's with 0 offset?
  193. 3.3L in my dakota?
  194. Leveling kits for 98 2wd v6 coil spacer size?
  195. 98 Dakota Help
  196. Odd Issues with 2000 Dakota
  197. Odd sound when driving after truck sits for a little while
  198. How hard is it to change a 2wd to 4wd
  199. Replaced battery and now it won't Idle- 03 Dakota
  200. Blower motor troubles
  201. No start.
  202. Black stock rims?
  203. Small lift, different shocks needed?
  204. Opinions... 33x12.5 or 33x10.5
  205. What the Hell is this thing???
  206. Problems after replacing IAC and TPS
  207. Homebrew CAI
  208. How much would you pay for my truck?
  209. Dragging brake & dash lights
  210. New To Me 2003 (UPDATE)
  211. Tapered (NOT) lift blocks
  212. truck is not happy, lots of MIL
  213. 4.7L to 5.2L conversion
  214. 99 Dakota sport 5.2l Trasmission Help
  215. Truckin Fast Wednesdays: Dodge Dakota smokes a Silverado around an oval
  216. Tuner ideas...
  217. Radiator
  218. This may be a stupid question...
  219. Can anyone help!!
  220. Guage cluster calibration
  221. give 3.9 more hp
  222. And begin the drivetrain underhaul
  223. question regarding front end checks; upper ball joint
  224. R/T Shocks
  225. Reving engine while at constant speed or idling
  226. Auxilary Fuel tank?
  227. What the heck? Transmission issue...
  228. Rebuilt Transmission is overheating
  229. Windshield "frame" part?
  230. My baby won't start!
  231. Manual Transmission Troubles
  232. reverse lights blow fuse
  233. Cold Air Induction, Do You Need It?
  234. Dakota brakes suck!
  235. Just got a used A/C Box $45 loads of Pic's
  236. where can I find the Conferr Roof Rack
  237. What should I look for when I go to buy my 2003 dodge v8
  238. Problem with brakes on a 02 dakota
  239. New stuff!
  240. Lifters and Ball Joints info please
  241. Projector Halo fog lights wiring?!
  242. Monstaliner?
  243. bought a 4x4 quad cab smoke silver
  244. Best spark plugs for 3.9L V6
  245. oil change and oil interval question
  246. Intermittent idle problem..
  247. 2002 dakota sport trans issue
  248. Problems.. any help apreciated.
  249. Need New Shocks?
  250. Something is loose in suspension...
