PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Selling what's left of my truck
  2. Need help!.. TPS or iac problem?
  3. Bad bearing, can I make it home?
  4. ABS and Pbrake
  5. restall convertor
  6. Rear window replacement
  7. Damage assesment
  8. It's a white Christmas! Post up your snow fun...
  9. Built Myself a New Sub Enclosure
  10. 04 Dakota...overheating issue???
  11. 2002 dakota quad cab v6 4x4 transmission help!!!
  12. A Chevy owner NEEDS the help of a Dodge Owner!
  13. High Mileage chemicals ?????
  14. Do I have/where is my stock e-fan?
  15. transmission help
  16. Dakota-Jeep TCM swap Mod?
  17. Stuff in oil
  18. short antenna
  19. Lifting 2wd Dak
  20. 2002 Dakota ignition/electrical problem
  21. Is it possible to remove Sliding Rear Window?
  22. 2000 dakota remote starter help!!!!
  23. What is this for?
  24. Advice for Power Adders
  25. 4wd full time
  26. 97 dakota no power backfires and pops
  27. PLEASE HELP!! '99 Dakota Sport Looses Power and Makes popping noise
  28. Headlights hack
  29. Dak won't shift into 4th
  30. not starting!!
  31. Rear end issues
  32. fog lights install
  33. Tranny not shifting into OD
  34. Merry Christmas!
  35. Do you have a Name for your Dakota?
  36. Found the ole Dakota on CL
  37. code P0441 issue
  38. Craptastic aftermarket shift lever HELP!
  39. Reverse Drone
  40. U-Joint or something else?
  41. fathertime55
  42. Need new shocks Recomendations?
  43. Need Help
  44. Metric or SAE?
  45. Pretty cool Dakota!
  46. Bad rust on seal between passenger floor panel and firewall.
  47. Battery cable grounded to fender
  48. Spindles
  49. draincock location
  50. '00 Really Weird Heater Outlet problems
  51. Error code P1594 on 2000 Dakota Sport 4cyl
  52. 4x4
  53. installed used transmission
  54. Lifted Dakota Mpgs
  55. Will getting rid of resonator's affect anything?
  56. Pls help! Back-up plow truck??
  57. 1999 Dodge Dakota Sport looses power
  58. Manifold leak & car shuts off
  59. Transmission Help
  60. lowered truck is killing my balljoints!
  61. Engine trouble
  62. any easy help for sloppy shifting 545?
  63. hard start when warm
  64. no hydraulic pressure at rear brakes
  65. truck stalls
  66. Fuse Box Relocation
  67. 04' QC 4x4 Blowing Parking fuse with Trailer.
  68. Air bag light
  69. Grinding/Popping/Click noise when in 4WD
  70. leveling kit installation
  71. 4x4 issues/ wont go out of 4x4 back two 2x2
  72. Check Engine Light.
  73. Hi all whine ??
  74. 01 dodge dakota problems
  75. air bag and brake light
  76. 4.7l doing a 0-80 pull
  77. Fire Truck Horn
  78. 04 dakota
  79. Synthetic oil
  80. 2001 Dodge Dakota problems!!!
  81. 4x4 question
  82. 04 Dakota trouble
  83. hydraulic tappets
  84. bull bar
  85. Stripped a transmission pan thread
  86. spark plug gap
  87. Where did you mount your IPF 968 lights? (No bull bar)
  88. Differential repaired, making noise now
  89. 04 Dakota trouble
  90. O/T forum search?
  91. 97 Dakota OBD sensor fuse location?
  92. Joining the 2nd Gen crowd
  93. P0733 code .. again but getting closer
  94. Mode Door Actuator and linkage issues
  95. 1998 3.9L V6 transmission will shudder
  96. radio turning off and on
  97. 1997-2000 Dodge Dakota OEM Service Manual
  98. 3.9L CEL misfire on 1,3 & 5 ???
  99. cast mopar p5249807
  100. CEL Flashes
  101. 5 speed transmission help needed
  102. 2002 Dodge dakota help
  103. 'Wow' moments with your Dakota
  104. Dodge dakota tie downs
  105. cabin/ac filter??
  106. 2000 Dakota "lift"
  107. Radiator Replacement Problem
  108. Flashing Headlights.
  109. Quad Cab Headliner
  110. 2000 dakota bug shield from "storechampion"INSTALLATION?!?
  111. PM Schedule Differences
  112. newbie wheel question
  113. Dash light color
  114. 2000 dodge dakota 3.9L
  115. Difficult Situation with the Differential
  116. 2001 dakota drivetrain brackets obsolete?
  117. Changing master/slave clutch
  118. need storage ideas
  119. Just bought my first dodge truck looking for advice
  120. Need help w/p0118 code.....
  121. Heater blows cold - tried almost everything
  122. drive shaft broke
  123. loud whinning noise
  124. Tonneau Cover questions,
  125. rear end. squeak, pop, crunch sounds
  126. Heater blower not working
  127. fuel tank
  128. 5.2L Plenum Plate
  129. rear bumper
  130. 2000 3.9 self shut down
  131. 2000 R/T - few problems
  132. needing a key
  133. 4.7l oil emulsion question? pics*
  134. ABS module wiring diagram?
  135. MSD ignition over stock?
  136. (Idiot!!) Wrong Oil
  137. Front diff: swap 99 into 2000?
  138. V8 motor build...
  139. Update to keyless entry
  140. Ride Of The Year! Go vote.
  141. 99 5.2 dakota randomly Dying..Any Ideas??
  142. Fuel filter
  143. Project, need some help/advice
  144. Heater core replacement
  145. Exhaust pipe
  146. Power door lock remote
  147. Tuners: SCT Hemifever VS. ?
  148. Oh no - Fluids help
  149. 97 Dakota Odometer flashing, all gauges do not work.
  150. All lights flashing while driving
  151. Torsion Bar Blues
  152. tire/rim question
  153. flex plate and paint
  154. Transmission I D
  155. poor lighting - help
  156. Classic Looking Engine Bay
  157. Infinity Stereo Help
  158. NEED HELP! Truck will not start...
  159. Have any ideas? Truck will not start...
  160. 3.9L motor help
  161. Where to get ? Seat Cushion for 1997 Dakota
  162. 2004 Dakota Tweeter question
  163. Replaced PCM, truck wont start
  164. Fan Removal
  165. Another 4wd question/problem!!!
  166. Chewed engine harness options
  167. Exhaust manifold bolts.
  168. radio
  169. Shaker hood - Sell or install?
  170. crankshaft sensor
  171. Knocking sound...
  172. Custom upper control arm mounts
  173. Can I unplug my a/c compressor for the winter?
  174. Tranny front seal leak, end of the road?
  175. Problems with idol
  176. will 16x12 rims fit on my truck??
  177. engine noise
  178. Lower rad hose is cold please help its cold up here!
  179. Performance/Handling Expectations (Tires)
  180. 2002 Dodge Dakota lift
  181. 42RE/46RE compatiability? (Alt title: future is set)
  182. Roller Rockers
  183. mpg
  184. 1999 5.2 motor pings
  185. fan/steering issue.
  186. Coolant loss, head gasket?
  187. headlights
  188. 1998 Dakota Info Labels & Plates
  189. My SAS thread
  190. 97 Dakota 3.9 no start
  191. 97 Dakota asd relay location
  192. 2003 Dakota Charging Issue
  193. Headlight adjustment screw size
  194. Bypass hose
  195. Valve Spring Compressor
  196. Loss of power & Loud hissing noise under load
  197. recirc door?
  198. '98 Dodge Dakota -- Max Tire Size?
  199. Does anyone know what centre cap fits?
  200. 2003 4.7 v8
  201. floor mats
  202. PCM / idle question help plz
  203. Thermostat housing bolt size - HELP!
  204. truck turns off while driving, lights flicker
  205. Happy Thanksgiving
  206. Best way to access fuel pump?
  207. 4x4 service light
  208. Rear Shackle Rusted Through
  209. No Brakes!!
  210. 1997 Dakota, not much heat
  211. Remote start turn signal issue
  212. Msd 6A ignition box???
  213. Driveline noise
  214. Electrical Noise Ignition? Injector?
  215. ABS/Brake Light - Module Replacement Cost?
  216. Finally put a Powertrax No-Slip in my 9.25" rear axle...
  217. Intake Resonator
  218. Valvoline Next Gen
  219. brake upgrade question
  220. Looking for a Truck topper
  221. overdrive question
  222. This is what more guys use an F-150 for..
  223. Odd brake issue, engine revving
  224. Strange Chirping Noise
  225. Project Dakota 98
  226. Widband O2 Sensor
  227. TPS: how low is too low?
  228. Level/Lift
  229. Anyone using a radar detector?
  230. heater core recommendation
  231. 2001 Dakota r/t im looking at
  232. Factory Alarm
  233. help,4.7 engine swap
  234. new car/old truck
  235. 98Dodge Dakota sport Hans manual
  236. rotors
  237. advice for 5.9 rebuild??
  238. Factory Rid Height front
  239. Failing Torque Converter?
  240. front drive shaft
  241. ABS and brake light come on at 35 miles an hour
  242. NV-231 4WD Operating Light Out
  243. 98 Dakota Engine swap
  244. My latest dumb question, oil/filter related
  245. Messed up O2 sensor
  246. Electrical Short/Power Surge???
  247. aux trans cooler line routing
  248. Bed mounted box to hold tie downs and straps?
  249. oversize brake pin replacement?
  250. Oil pressure gauge info
