PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Starting issues
  2. 95 to 85 motor
  3. Brake line troubles
  4. 4.7 HO/STD hybrid build?
  5. Thermostat
  6. P0432 Fun
  7. 2.5 Boosted?
  8. NV3500 Rebuild
  9. Shopping Help For Muffler Set
  10. Bolt compatibility question
  11. Blown tranny
  12. Poor running 01 4.7l qc
  13. 2000 DAk 4x4 upper control arm bolts rusted
  14. 97 Dakota Bouncy Ride on certain freeways
  15. 1999 318 'kota wont start.
  16. 2001 Dodge Dakota Passenger Side Heated Mirror w/ backing plate
  17. 01 Dakota 2 mystery plugs.
  18. 4Hi light blinks
  19. My 04 Money Pit
  20. Turn Signal Failure Only in Left Rear - Tried Everything! (I think)
  21. Removing leaf spring/shackle bolts
  22. Did 2nd gen manual daks come with AX-15?
  23. Crank no start after wiring harness plug replaced
  24. VIDEO: How to set Fuel Sync
  25. ABS and brake light on
  26. 1999 Dakota 5.2 radiator drain plug leak
  27. Radiator drain valve leak fix?
  28. Truck starts but immediately dies
  29. 2000 2.5L Sport Starter hit and miss
  30. engine replacment
  31. 1998 Dodge Dakota SLT Radio Not Powering Off
  32. Broken column shifter
  33. Dakota
  34. 4 door 5.9 Dakota?
  35. Intermittent stalling and erratic RPMS
  36. Issues with cv axle
  37. Mil led
  38. Sway bar bushings
  39. 2001 Parking Brake Tensioner (part #52009868AF)
  40. 1997 Dakota diesel swap
  41. Gauge issues
  42. 2000 Dakota 4.7L, Oil Leak Issue
  43. Crank no start after wiring harness plug replaced
  44. 03 Dakota 5.9 hesitates and popping at low speeds
  45. 2002 Dodge Dakota Headlights don't work
  46. Factory and Aftermarket Gauges
  47. Lost of Volt power
  48. Lost of Volt power
  49. Dakota shuts off when slowing down
  50. Towing Mirrors
  51. Brake warning lamp 2002 Dakota 4x4
  52. Keyless entry issue, but fob still sending..
  53. Jacked up 1999!
  54. 2003 QC4X4 4.7 Rear Shocks
  55. '99 3.9L v6 stalls at low speeds or when stopped
  56. Turn signals flashing rapidly both sides
  57. 1997 dodge Dakota
  58. Hi beam problem 98 Dakota
  59. 2002 Dodge Dakota Front Transfer Case yoke
  60. Help! How do i drain the fuel in the tank? I depressurized using the Schroeder valve
  61. Radiator upgrade
  62. 1997 Dodge Dakota Custom Interior
  63. Testfahrt
  64. Code 1765/0763
  65. need a scanner
  66. 1997 Dodge dakota 4x4
  67. Park brake and ABS light on
  68. 2002 dakota harness in an 01 quad sport
  69. Steering Issue
  70. Moving rear axle from top to bottom of leaf springs.
  71. Junkyard gems
  72. 2001ish Durango dash top in 2003 Dakota
  73. Band symptoms/adjustment
  74. Mounting Flywheel
  75. Mild shake
  76. dash board light part number
  77. Driveshaft 3.9 to 5.9 42re-46re
  78. Factory amp issues. Infinity system 02 dakota
  79. Help!!! Performance mods
  80. Intermittent stalling/dies
  81. Front Disc brakes
  82. Broken into!
  83. fuel issue (i think)
  84. 03 dakota 3.9 to 5.9 and 42re to 46re
  85. Alternator change out
  86. Complete Clutch Confusion
  87. 1997 Dodge Dakota engine swap
  88. Cv shaft slipping off of stub shaft
  89. Any copper nickel brake line kits ?
  90. Replacing Speaker, 2001 Dakota Quadcab
  91. 03 Dakota rear axle
  92. Lifting a 2001 dakota sport
  93. 02 Dakota "No Bus"
  94. Transmission replacement woes
  95. Nfg
  96. Power window issue
  97. fuel pump replacement
  98. 2001 Dodge Dakota
  99. Climate Control
  100. Error Code P0700
  101. NV3500 trouble
  102. 1998 Dakota 5.2l starts then stalls within seconds
  103. Ground wire question
  104. P0340 Engine code camshaft position sensor question
  105. Need Help! Out of options. (Its a little wordy)
  106. Sticky fuel guage/sending unit
  107. 1997 2WD 3.9 V6 - IAC Interconnectability
  108. One headlight dim
  109. Help! Can't figure this truck out...
  110. Spudders on restart once warmed up
  111. New member, old problems....R/T
  112. Won’t Turn Over/Cruise Quit Working
  113. 2004 4.7 Dakota overheating at idle
  114. 02 Dakota 4.7 overheating at idle and city driving
  115. Overhead cam
  116. Should I use dialectric grease in this situation
  117. New to forums and looking for advice.
  118. 2004 3.7 Power Steering
  119. New remanufactured install
  120. 98 Dakota 4X4 rear differential bearings replace
  121. Engine swaps
  122. DJM control arms
  123. 2004 Dodge Dakota Starter or Fuel Pump
  124. wiring diagrams
  125. Finally: an LED compatible Combination Flasher
  126. UCA Ball Joint Spacers and ball joint flip.
  127. Ac blows on and off
  128. Air suction test/plenum
  129. 1997 Dakota no start help
  130. 2001 Dakota Strut Issue
  131. Torque question
  132. 360 rt engine swap issue missing 2nd set 02 sensors
  133. 1997 Dakota tranny takes awhile to engage when first put in drive after sitting.
  134. Suggestions.... :)
  135. 99 Dakota Park Lights Flash with Blinkers
  136. 98 3.9 sport with infamous dies while driving issue
  137. No bus!!
  138. Shift Cable at Transmission
  139. 1997 dakota 2WD transmission issue
  140. 1997 Dakota blowing signal and Emergency Flasher fuses
  141. CODE READER port
  142. What Tools to Carry in Your Truck
  143. Intermitant starting
  144. Wheels and tires
  145. 2.5 compatible transmission 2001 Dakota???!!!
  146. 42rle problems
  147. RE42 and the Car are not driving
  148. 2001 Dakota 4.7L 45RFE no forward or reverse!
  149. another towing question- tires
  150. Stalling 02 Dakota
  151. Jacob
  152. obd codes
  153. A/C clutch cycling
  154. Emissions swap? Lol
  155. No fuel pressure, what else could it be.
  156. Nv3500 help
  157. Tranny lube
  158. Clutch pedal not returning 2000 Sport
  159. 2 wheel abs module circuit board burnt
  160. Load distributing hitch
  161. 2001 dakota hoses
  162. Lug nut torque
  163. Question about CPS
  164. Rack and Pinion "gear to frame" bolts issue
  165. Lowering coilovers 98' Dak
  166. 8.25" LS differential, changing oil found this
  167. Transmission Dip Stick Tube h e l p!
  168. Brake drums 1mm too thin after turning
  169. Decent headlight housing
  170. Cluster woes.
  171. Trouble shoot
  172. 2000 3.9 dakota - what should I look out for
  173. Intermittent Fuel Level Gauge
  174. Front Prop shaft
  175. 03 3.9 to 5.9 4x4 quad cab
  176. No AC when on lowest Fan Speed
  177. Intermittent Power Steering Help
  178. Help with torsion bars
  179. Brakes - No fluid at rear bleeder screws
  180. Dakota Speakers
  181. How to get code for check engine light 04 Dakota
  182. Question regaring Idle speed at full operating temp
  183. Torsion sag
  184. 2003 PCM question
  185. Harness replacement 01 dakota 4x4
  186. Is my thermostat working properly?
  187. 4.7 woahs (go figure)
  188. Well, Rose Reds up to it again,
  189. Vapor canister hose connection
  190. Front brake pulling to the right
  191. New to me 2nd gen 2001 dakota
  192. '98 front differential cover gasket
  193. 2000 Dakota Questions
  194. old dakota(97)
  195. 2002 Dakota miss fire PLEASE HELP!!
  196. Where is my oil going?
  197. engine problems
  198. Intake manifold bolts do i need to replace with new ones on my 2000 dodge dakota 3.9l
  199. 01 4.7 Quad Cab Pop-pop noise from front middish.
  200. Question RE CTM Replacement and Flashing
  201. 02 Dakota heat and a/c knob does not switch back and forth
  202. Rebuilt rack and pinion, steering wheel shaft. ujoint rubbing on the left motor mount
  203. help with motor swap info
  204. Code 1491
  205. Seems to be no anti freeze going from the reservoir to the engine
  206. 4.7 manual to 5.2 swap
  207. Found a clean low mileage 2002 extended cab.... but....
  208. P0442 on 3.9 v6 Dakota hoses
  209. HVAC blower
  210. Exhaust manifold Bolt identification
  211. Coolant leak
  212. PCM swap with other gen 2s
  213. Looking at a 99 R/T, what should I look for?
  214. front driver side brake, 2000 Dak
  215. 04 Dakota parking brake troubles
  216. Gauges
  217. How many quarts of transmission fluid for 2010 dodge journey
  218. Nobus code
  219. 2001 3.9 l | Loss of power | Bog down at slow acceleration | Backfires
  220. Ignition ring light wont go off - 98 Dakota
  221. 98 5.2 Dakota jerks hard at highway speeds
  222. 99 dakota shuts down when warmed up
  223. 98 Dakota 5.2 4wd
  224. 98 Dakota 5.2 4wd
  225. No Bus 2003 Dodge Dakota Sport 5.7 L
  226. Turn signal and flasher not working
  227. Interchange Driveshafts
  228. Sway bar bushing changing on lifted 4x4 Dakota
  229. intermittent ignition process 2000 Dakota, automatic
  230. Installing 6/9 speakers in a Dodge Dakota 98
  231. 1998 5 Speed - Rear Axle 75w-90 or 75w-140?
  232. 2001 Dodge Dakota 4.7 misfiring
  233. Can you change the EVS II code?
  234. 2002 Instrument Panel
  235. aftermarket radiator difference(s)?
  236. 2004 4.7 Running Hot
  237. help with shocks
  238. central timing module
  239. Dakota R/T exhaust/fuel problems
  240. Gov Pres Solenoid
  241. Locating turn signal flasher relay - 03' Dakota
  242. 1998 Dakota 5.2 will not start
  243. Turn signals not working on one side? Possible fix.
  244. Maintenance Schedule for my 1998 5 Speed?
  245. 2000 Dakota with posible computer problems
  246. Brake Lights Won't Shut Off!
  247. 2001 DK V8-Is there a way to prime oil system
  248. 9.9 Volts at A6 Combination Flasher
  249. Occasional grinding sound from rear wheel
  250. 2004 cv axle
