View Full Version : 2nd Gen Dakota Tech
- question about diffs
- Header Flange
- front pumper!!!
- Dakota With Natural Gas Conversion.
- R/T read end
- HIDs installed
- Easy to install Radiator?
- Rear End
- Revs High
- What kind of rear gear?
- shocks question..
- new and improved exhaust vid
- anyone in Central Fl. need a bedliner?
- Throttle body
- Which Tuner?
- 180,000 and still goin
- Tranny fluid
- dealer is retarded
- v8 Dakota Shroud
- Cycle fest in auburn Indiana
- Transmission Swap?
- Fluid Change
- 2001-02 545RFE flash possible
- Keeping Stainless Stell Tail Pipes Clean
- OBD II PIDS mapping for the 3.9L V6?
- A-pillar trim?
- Pathfinder tires
- pics, if anyone has a lifted 2wd
- A/C cycling on and off
- LED, gauge lights
- lug pattern
- Rough Cold Start
- Cold air intake and exhaust upgrades
- "Bank 1, Sensor 1" Code. Which O2 Sensor?
- Heater Core Rep
- Exhaust Lowered -- And Coolant Leak!
- Shifter
- Badass Pic. 5-10-08 Dak Meet in TX at Hooters
- Dak won't start - Please Help!
- 3 inch body lift problem
- Power Steering 04 Dakota Problem
- Dakota RT owner's
- grillin
- im kinda pissed!!!
- Turbo 3.9 Mag
- Connect gauge air/ratio
- high engine rev at start up
- 1998 Dakota Tires
- door lock noise
- evaporator drain plugged
- rpm surge
- Brake Pads
- Good news
- Rear Wheel Speed Sensor...
- tilt the wheel then lights turn off
- got bored, installed neons
- Info and a ?
- Coolant leak on tranny dust cover
- Better Sound
- 02 Dak QC Diff oil change
- replaced tranny filter and fluids 4.7 4x4
- HO cams- thinking about 206's
- Heater-A/C Control Calibration
- Removing Door Panel- 02 Dakota Sprt
- Troubleshooting '98 cruise control
- How about some winter!
- Fan no longer operates
- lube locations
- IAC valve
- 2004 Dodge Dakota shocks
- Drivers side mirror not heating
- Front Drop
- Overhead computer
- E3 Spark Plugs
- my next project
- Body Bolt Threads
- Wheels -16" to 15" Any help?
- Delete
- Finally I'm free!
- CAI placment
- Regulator/filter
- Tow package trans and power steering coolers?
- Front end POP
- Squeek when releasing brakes
- Rear axle longevity?
- more lift
- Help.. info needed..
- Any ideas
- Rear Bucket Seats?
- help
- Halo spark plugs
- Left turn signal blinks faster than right
- 86 Datsun pickup
- turn bulb replacment
- New Tires
- glass replacement ???
- Electric Fan
- High Altitude Operation, Hauling & Clutch Fan
- Which rims?
- HHO Fuel cell
- Finally got some pictures....
- Low End Torque
- Engine has clatter sound at startup
- body lift
- engine
- AC vent squiling
- batma13s new bed progress
- Aftermarket Taillights...
- 02 senser ?
- Towing
- Need some quick general info on 2001 dakota please
- What rear ends fit the '97 Dakota 4X4
- buying a 2000
- 04 Quad Cab, passenger seat doesn't recline, do your's?
- CAI
- PLUG change
- Truckin' Does a Dakota
- wheel bearing
- 42re
- Deer
- Overfilled tranny... can i just syphon it out?
- My center cap is gone from my truck!!
- friction modifier for 2wd?
- to much oil???
- Any changes in headlight housing 1997-2004?
- STS Universal Turbo Kits -- READ!
- help me find a motor
- Why are people stupid?
- is a performance chip worth it?
- new headlight bulb help?
- uh...pre-cat disconnected = better MPG?
- No Brakes
- Centerforce clutch Longevity Question
- 5.9L Engine Swap
- new throtle body
- battery gauge
- AC not blowing out of vents on 03
- Torsion bars
- Chris1974: what is your tire size?
- 97' dakota
- running rough
- Quick Exhaust Question
- 4 pole trailer wiring on 2002
- LoudPedals Exhaust
- shocks for '03 QC 4.7
- Is there a deadline to respond to a recall
- sold the dak
- Does this sound like a balljoint?
- How Can I Build Up My 5.9
- stock 5.2/5.9 intake manifold.
- Oil pressure question
- dakota running rough
- Bad Brakes
- BAD NEWS MY 2000 4X4 REAR BLEW UP
- Transmission Solenoid..
- 4.7 HO
- Clanking all over the place! (well, almost..)
- 1998 4x4 Transfer Case Vent Hose
- nitro on my truck?
- Tonneau Cover
- new shift knob!
- V8 throttle body question
- LAST TOUCHES
- 2003 dakota air bag light on
- Head bolt pattern
- 2001 dakota engine swap?? 5.7 hemi for 4.7
- Few questions about my Dad's Dakota
- im f n pissed
- Easy to change tranny fluid and filter?
- 5.9L magnum spark plug
- Horrible gas mileage
- Lighter Flywheel Option Available...? Bad idea...?
- 98 prewired for foglights?
- lowering a 4x4
- Let's talk mods gentlemen....
- Ram Air hood
- Magnaflow muffler?
- High+low beam mod?
- Speaker Suggestions
- Getting water in the HVAC ducting...
- Woot got my PPHs thank god.
- Check crank/Cam sensor?
- Took out the cats...how's it sound
- PO 340?
- Oil.
- Wheels that will tuck into wheel well!!!
- thermostat
- More balls for my 3.7...
- bolt pattern
- now what
- tranny issues
- NEED MORE POWER!!!
- running lean?
- is it possible to twin turbo the 5.9 r/t?
- Ye Olde Crank Sensor
- Distributor timing
- tranny fluid level
- Replaced Diff, Now clutch is out...
- Changing a silly valve cover gasket
- duel throttle body or six pack for magnum
- Rims. ??
- Another New Exhaust Clip
- Durango rear end
- Shaking & Rattling
- TB bolts
- 2004 Quad Cab cruide issue
- Transmission problems??
- front brakes binding-up
- 4.56 swap info
- new wheels and tires
- You have a Dak? You live in Texas around DFW? Look here...
- a couple ?'s
- 5.9L half runs
- o2 simulator where to buy?
- pcv valve
- dakota demon?
- 7-way wiring & trailer brakes
- O2 sensor code - Which side is Bank 2?
- Error code P1281
- Lift kits
- Stalls when shifting down to 2nd
- Factory Radio Issue
- rear ends
- R/T Problems
- Homemade Mesh (gutter guard) Grill DIY
- Running truck with added water power
- speakers
- engine swap idea
- Just bought a new to me Dakota
- gettin rid of dakota
- Gator Belt?
- rear end hook up
- Weird Starting Problem?!?!
- 5.9 flex plate
- JasonA's Exhaust Video
- ifs diff question
- CB's and PA's
- dakota manual?
- bump stops???
- Newbie with a question
- dakota vs suburu
- morning hiccup
- Lighting Issues
- Subwoofer placement
- center console lid latch
- 01 Dakota purchase advice
- Emerald Green Pearl (PGF) Paint Match
- Transmission question.
- 2001 Dakota
- Transmission Issues
