- rear trans mount
- up-stream blues.
- Performance chip V6 Mag 1999
- Upstream & downstream oxygen sensors.
- Turn-signal problem (possibly figured out - just need proper part name/ number)
- my 00 Kota v. 11 mitsubishi endeavor crash
- What would be the best bang for my buck?
- Aftermarket Lash Adjusters
- 3.9 auto to stanard tranny swap????
- 98 Dakota stalling going from reverse to drive
- Need help on swapping my engine
- 1999 Dakota 5.2 grand cherokee intake manifold?
- Belt T against Coil
- 03 Dakota A/C & Heat issues no fan!
- terrible gas mileage .. How to improve it
- New member here making noise
- dash/tail light problem 1997 dakota
- need a TB air cleaner
- 99 dodge dakota rear end help
- looking a buying a 01 dakota but...
- Grille guard compatibility
- Front-end work
- Staying Mopar but switching forums + Dakota Problem
- Throttle Body swap questions
- Fog lights
- 4wd help
- living in past
- You Don't See This Everyday! - Or Do You
- I am saying goodbye to the dakota section
- How Many O2's?
- 2wd tires
- 3"/5" pro drop kit/ need shocks
- exhaust manifold removal
- Rear end swap
- Do differential's click when going bad??
- P0420 code
- Door Hinge pin and bushing
- 99 5.2 dakota dies when i come to stop light
- HIDs stopped working
- Dakota ABS light reset
- Vacuum problems?
- 2003 Dakota trouble starting
- Strange freeze plug size
- Slight jerking at 50-55
- flowmaster fitting problems
- Speaker question
- Power Issue/Starting Issue?
- "no bus" heads up!
- door panel
- Removing 3.9 Engine in 2wd
- Tail shaft of t-case leaking
- Light output of Eagle Eye vs. OEM headlights?
- Those Pesky O2 Sensors
- Rear differential leaking and fluid question
- Need to know how to change an oil pump
- Vibration while on the highway
- 2000 dodge dakota parking lamps not working
- Dakota brakes squeal...but only for the first 1-2 mins it's on
- camshaft question
- Bodywork Advice
- T-Case Swap
- 2000 Dakota not turning over-help
- Finally got spacers on!
- CD Deck and speakers
- Loss of power from vacuum leak? Need help
- Paint! (Atlantic Blue fellas)
- 2001 dakota power windows not working
- Dakota Shifts without brakes
- Oil pump problems
- PA 3" lift #60043 on a 1999 Dakota?
- trans oil flow
- 4.7L coil o-rings
- Blower Replacement
- New ride!
- Wheelin on a moto x track
- How to disable check engine codes
- superchip 3715
- Dakota O2 sensor.
- WTB: 99 Extended Cab - V6 Jack Set
- Overdriv won't engage
- 00 dakota update
- New Dakota Owner with Transmission Issues
- Bed covers. Cargo racks/roof racks
- how much can i tow?
- Is any p/s whine normal??
- Couple new pictures
- ABS RWAL issue
- 2000 Club Cab rear speaker size?
- Thinking about doing some lifting
- 1998 transmission problem
- 2004 Dakota..6th Water Pump...Help!
- 97 Dakota 318, runs bad... NO power
- 2000 Dakota Quad Cab 4x4 Sounds Issues
- 2000 Dakota Rear End Noise
- Worth it?
- Need a 42re transmission
- 2000 5.9l V8 engine?
- Lift confusion
- Pretty sure I just got raped...
- misfiring, refuses to start
- Exhaust for the 2.5
- RB1 Installation
- New Tires for Dakota
- CAI help MPG?
- Truck still wants to go while stopped
- Airaid or CGS CAI?
- LOUD popping! Help
- 1998 3.9L engine swap with 1991 5.2L
- 2000 Dakota Transmission Problems and idling problems
- Random Downshifting?
- Steering stop adjustment?
- Who would be interested in a dyno day?
- 02 sensor problems
- 98 Dodge Dakota 5 speed conversion Flywheel sensor issue
- 98 Dakota 3.9l owner
- clicking sound when I accelerate?
- Royal Purple power steering fluid Bad ? ?
- New guy/ New truck!
- new dakota owner with question about wheel adapters any help is appreciated
- New guy
- 99 Duelly gets new instrument cluster
- i have no heat....help please?
- Let's play name that tick
- Kota got a little make over
- 2005 Dodge Ram won't pass smog
- Question re thermostat
- What to look for?
- 45RFE reverse not working
- 1999 R/T Check Engine Light don't light ever
- I thought about another goodbye
- Need Some Help!
- Massive electrical problems (2002)
- Help!! My 4x4 is f***ed!
- Got my truck back...
- dakota r/t transmission issues. 46re
- Does the 45rfe pump in Park?
- Ride of the Month Vote!
- Factory Infinity Sound to be Replaced
- 5W-30 or 10W-30
- dakota hesitates when i start it
- Road noise or vibration, goes away on right hand ramps
- Randomly wont start! No click or anything. Then fires right up??
- heater core replacement, no other choice
- Transmissions issue
- New car...still have the Dakota though :-)
- Transfer Case Module
- Need Wheel Spacers ASAP
- lower control arm bushings
- 1997 dodge dakota headlight problem
- 4x4 help!
- Dakota door interchange
- 2.5 vs 5.2
- P0449 Code
- Transfer Case Swap
- Third time!!! Unbelievable!
- My Name is kethone New to Forum
- No Compression in brand new motor
- Oversize Ball Joints?
- TPS Mod
- Very thick liquid in expansion tank? 4.7 Also small coolant leak.
- Next Vehicle? Another Dakota?
- opinions please :)
- Need little help
- Why am I running LEAN
- No Reverse Lights
- ROTM Voting and Nominations!
- Failed u-joint carnage...some help please?
- How to take off seat belt
- performance programmer chip
- check engine light!!
- Single leaf springs?
- P0113
- Car Stereo Install Help!
- purolator new filter
- Is there a DIY way to remove fan clutch
- HELP 2000 Dakota 4.7
- 02 Dakota popping noise from engine
- Installing electric fan question.
- 02 dakota with non abs hubs (with light on )
- My CAI is here
- rack repair question
- Throttle body cleaning
- Door Trim issue.
- Parts for my Dakota
- Best way to store aluminum heads
- 02 Quad Cab Front turn signal
- Shocks for 98 Dakota, 3" lift and 33's
- 2000 Dakota, crank no start
- trasfer case help
- Adding Air Bags
- One code turned into two!
- Different brand belt tensioner
- Front end problem 02 V8 QQ Sport 4WD
- 4-Wheel drive issue
- Shocks
- NV1500 Short Shifter
- 44RE band adjustment instructions? Master tech?
- Haynes or Chilton manual?
- Tranny Control Solenoid
- 00 4.7 Heat/Air On Causes Pulsating Engine Sound?
- Hit a deer...
- My 45rfe blew the pump.
- Fabrication has begun!
- window keeps poping off track
- re keying a door handle lock
- biggest brake rotor for 16 inch wheels?
- Installing Hughes F1 Air Gap Intake Question
- Paranormal activity?LOL
- Some info on Auto Zone Power Steering pumps
- Headlight Assembly Screws
- 99 Dakota Dually Diesel gets rear air ride
- Durango IFS into Dak
- Hard Start 4.7L P0301
- poss trans or sensor problem please help
- 99 dakota issues please help
- 2000 dodge dakota 4.7 liter engine tick tapping noise
- 2000 Dodge Dakota Knock/Tap/Tick
- Truck stalls immediately if I release the gas pedal
- "no bus" problem
- overhead cousel
- Homemade $33 Cold Air Intake
- oxygen sensors
- Rack/power steering?
- anyone have Dunlop Rover RVXT
- headlight problem
- save$$$$friend parting out 2001 4x4 qc
- New to the forum
- tranny surges during hard stops and slams into gear
- half of my gauge lights are out.
- 2006 Dodge MegaCab Cummins Diesel problem
- @URBANRDNECK Headlights
- Interchanging doors
- help ctm problem?
- front end noise
- 2000 dakota suspension lift
- Replacing 2WD Dakota Front Lower Ball Joints
- General Grabber Red Labels
- gas leaking out of truck
- factory sound system
- Exhaust Question
- Code P0351 and Cutting out, Not firing back up Issue
- Rear axle LSD fluid?
- Changing seats again
- Cracked/bent lower A arm
- Jump Started 2000 dodge dakota Truck, Now all my gauges do not work and radio HELP!
- Tail light question
- I can't see!
- Bucket seat won't slide back
- Got a concern want an oppinion
