- V6 3.9l missing, help
- had a problem with my superchips
- Picked up a second gen
- 06 intake manifold swap + 180tstat review
- radiator drain plug
- brakes feel... soft?
- 4x4 knocking only when engaged..
- Knocking noise....
- TPS symptons - feels like transmission slipping
- Want to Switch Doors... Compatibility Question.
- What would my truck be worth with..
- yay ive got a warped block!
- Does anyone know if....
- 01 Dakota Smoking on start up
- 01 Dakota Towing Package Trailer Brake
- Difference between 2002 and 2004
- 15" Rim availability
- 2000 dakota no power at ignition
- Tire Size Question..
- Headache with headgasket *pic heavy*
- Need help with aftermarket H/U (Pictures inside)
- DF Chat?
- Wondering where my horses are. (Big trouble)
- No blower fan!!
- heater core installation question
- 2002 Dodge Dakota 3.9L
- Can a 5,9L fit into a 4.7L Truck
- fuel filter
- drive shaft question
- Which Trans
- My New System :D
- Weird Starting
- 98 Dakota A/C recharge
- Coolant to water ratio?
- Good deal at Advance
- Look what a Dak can pull
- Lower Ball Joints
- Dorma EZ Drain Plug
- Torsion bar questions
- Front Wheel Bearing
- truck rolling in park and reverse with brake on
- My New blue dakota quad on 20's!
- Manual valve body
- oohhh new parts on the way!!!
- Who says one leggers can't mud?
- Has anyone see this before
- Rear Speaker Wiring
- Prepping to fix truck
- mysterious sound?
- coolant drain plug
- Whirring sound from trans when cold
- new to the forum and have a few questions
- 98 2.5L Intermittent Misfire
- Two part lighting question
- greenhorn with a 01' Dakota
- 03 Dakota Trans Whine
- 42Re Question
- Temperature Problem?
- 2wd to 4wd swap?
- surprise CEL
- surprise cel.
- Replacing evap/heater cores soon
- TMR mod on 04 4.7
- Ideas on what the problem is with my v6 ? Stalling out.
- 3.9 Belt Too Long - Dealer Installed A/C
- Dakota AWD
- code 3391
- RT Chrome wheel skins?
- Gear lube confusion?
- Help me get more out of my 3.9
- Water pump - FYI for DIY
- low temp thermostat?
- A bucket list of questions.
- Lighting Issue
- Headers for 2.5
- 2002 V8 4.7 Dakota.. Service 4 WD light just came on.
- Were the interiors of these trucks always "Dark Slate Gray"?
- Grille Trade
- 3.9 5.2 swap will i need a new flywheel?
- Please help diagnose...dakota just died and wont start,and boss is pissed
- 03 SXT Parts
- 46 RE Transmission issues!!! SOS!!!! R/T
- stock headlights to HID
- Heater problem 2001 4.7L
- upstream o2 sensor
- 4x4 will not engage....grrrr
- Weird electrical problem
- So...anyone need a new fender? =P
- New air filter (pics and video)
- Help Needed - fire/burning/unknown piece of material
- 420 stroker?
- Why the hell does my truck have California emissions?
- Running Terrible
- ATTENTION!!!!!!!! In need of help
- where can i find parts?!
- 2000 dakota keys??
- 2004 Dakota Quadcab
- How to replace front CV joint on propeller shaft?
- Manual crank window hard to roll up and down
- my camber off
- what year motors will interchange
- electric shift 4 x 4
- why are my tires rubbing?!?
- Trans Guru Needed!
- WTB parts
- Headlight bolts
- Scratched paint
- 2000 4x4 rims - help!
- Is the ashtray supposed to be lighted?
- Under-Dash Air Leak Problem -Resolved :) W/ details
- COLD start squeal?
- What Does A Camshaft Position Sensor Do?
- Transfer case swap?
- Transfer case stuck in 4lo
- 1998 Dodge Dakota Help Won't Fire Or Start
- shift shaft seal?
- Outside Air leak coming from under dash
- First Video's of the truck in action
- grinding noise
- Why am I a retard when it comes to computers?.
- Fire started in my truck. Hazard relay ...
- Limited Slip?
- Question about changing Out 3.9 engine
- just bought a fuel pump
- 1999 dakota lift
- broken bolt
- 99 Dakota 5.2 doesnt want to get out of first
- Exhaust cutouts on 5.9L
- headlight covers
- turbo
- Auto parking lights
- Auto Down Window Switch?
- Cold Air Intake Questions for Custom Mod-Coming soon
- 2001 dakota drag truck
- injectors
- Whats this interior piece called?
- Question On Lift
- Anyone here ever reglued the window regulator to the window?
- Automatic door locking?
- 40 Series Flowmaster- 5.2L HAPPY DAYS
- help please 2001 dakota blower stopped working
- Belly pan gasket???
- Yet another tranny question
- hemi swap
- weak lifter?
- P0404 code
- rear brake problems
- America Eagle 058's
- transfers broke cant find parts
- Gas Mileage
- 2004 Dakota Half shafts
- I love snow...
- replaced trottle body
- Tail gate issues
- Rims Painted Black?
- P 1494 code
- cheap headers
- where can I find some more Hp?
- 3.9 Pinging, 3923's and 180 t-stat
- Transfer case HELP!!
- 3" Body lift please help Newbie
- replacement dome light cover?
- power steering is suspect on cold mornings. Pump going?
- Soot in tail pipe/ Strange smell/ Bad MPG
- output shaft speed sensor
- im lost now
- BG transmission service
- rancho sr 5000
- The Biggest Tire On A Dakota?
- Cheap Paint JoB!!!!!!
- review of falken rocky mountain tires
- engine temp
- trans fluid...and how to figure out what size rear dif
- How Do You Take Out A Creased Dent
- Possible tail gate problem
- Bosch Fuel injectors
- Should my Mileage be this BAD??
- Weak start, new battery?
- electrical problem
- '03 Hydraulic clutch adjustment?
- Question about custom grilles, ie..street scene style grilles
- Performance Chips
- Dak got a color change this weekend!!!
- lift kits 2000 dakota
- ticking/rattling during acceleration
- Method for switching from 4WD to 2WD?
- Dodge Dakota 3" Body Lift with 34" Tires - Front & Rear Diff. Gear Question's
- Where is 99 Dakota resister block??
- Code p0012
- low heat
- couple of q's
- Trasnsmission troubles revisited
- loss of power
- 01 Dakota slight downshift on the highway
- Mod Ideas?
- manual v8
- Throttle response
- OFFICIAL Moore "SRT" style hood group buy! Info inside!
- Ice sucks.
- Sway Bar Q's?
- used 2002 dakota questions
- Newb mod recommendations?
- weird feeling in brake pedal when in 4 wheel drive
- R/t 6speed
- Getting cool air to the engine?
- Lift Kit
- Clutch Fan / Electric Fan: A Discussion
- 1A auto?
- trannys
- quick tranny question
- Best tire?
- Changed spark plugs, lost mileage
- Possible to fit a sub in a Reg Cab?
- how to identify gears
- Tannmission Question
- dakota/durango shaker hood
- HELP with 98 Dakota front seat mechanism
- what size is my rear end
- I got my new throttle body!!!
- 2004 Dakota 4.7 weird smell
- Question about wiper blades on a 2001
- Valve Spring Broken
- 89 Dakota 3.9 no spark has fuel
- Guys Gals and Gurus.
- photo after lift and tires
- Transmission line pressure booster
- Dakota 4x4 SXT Ball Joints
- transmission problems
- grinding in four wheel drive
- dakota and durango engine interchange
- wheel bearing?
- 1998 Dakota 3.9l to 5.9l swap
- Power steering issues
- Stalling and no codes
- Question on changing transmission fluid...
- 2000 Dodge DAK 3.9L V6 Frost plugs
- Where is the fuse for the reverse lights located?
- Questions on Replacing Clutch - 2001 - 3.9L
- 2001 dodge dakota stalls on start up?
- Radiator issues
- Ditchin A/C
- Hooking Up PA System?
- might be bad?
- Outside temperature related starting problem
- My "new" exhaust
- clicking sound when i push pedal
- GPS Mounts Lets See Them!!
- Old School Tricks
- Brake light stays on - 1997 dakota
- Check Engine Lights does not light at start
