View Full Version : 2nd Gen Dakota Tech
- Squeaky clutch
- 08 Intake Manifold?
- Axle vent leaky !!!
- injectors 1,2,3,6,7,8 open
- wheeeeeeeee new parts!!!!!!!!!!!!
- headers
- 2004 Dakota, heater issues?
- 12 inch sub
- 4x4 switch not working '02 Dakota
- 1998 Dakota sevice manual ASAP
- 2002 Club Cab Speakers
- 99 Rear end is OUT!!!
- Got some halos on my dak
- Heres my ride..
- truck starts/ but dead
- built 3.9
- Exhaust Q's
- Guess what I found?!
- 00 4.7 dak 4x4 manual tranny problem
- finally gotta get it done.....
- STS Turbo Dak R/T
- lower steering shaft compatibility
- timing chain
- won't start
- crankshaft postion sensor removal
- 1998 Dodge Dakota check engine light
- Manual tranny question.....
- Multifunction Switch Harness Questions
- Got my 318 home today..
- clutch adjustment
- New Alpine type R and ported box
- Paint Ideas?
- Cargo Basket
- water pump
- Heater Resistor
- on board air time :D
- HID conversion
- 2000 Dakota 5.9 Head Upgrade
- Spark plug heat shields. PITA
- 99 dakota engine swap???
- Fun last night off-road....
- Proper Size
- Sub under jump seat
- where can i find.....
- 97 dakota starts and shuts off not getting fuel
- Tranny didnt get fixed, so now im spending 2k...
- power lock problem
- 97 Dak chime trouble
- porting a TB
- Need some help!
- What struts have you bought?
- TCM P0700 hell Thought I'd share my experience
- Pic request: 2wd dakota with 2" spacers & shackles
- super chip
- Help Me Please!!!
- Extang Revolution tonneau?
- probably been asked before, but i can't find it
- getting rid of some stuff.....
- Dash Security Light coming on
- Brake Issue - Make It Stop!!!!
- Durango Brakes on 2wd dakota??
- Removing Turning Lens/Side Marker
- TPS Adjustment?
- rtdakota2001
- 99 dakota idle issue
- Installed hub but it wasn't easy like i thought.
- How can i make my truck louder?
- making the new hood functional...
- w00t for craigslist!
- Hey guys
- 98 Dakota Tranny Problem
- Do-over
- Suspension lift 04 Dakota
- New R/T owner with a tranny issue
- New Exhaust
- Wheelchair dude's Dakota w/ Roof Top Tent
- New Seats Installed. Sexy!
- busted rear end
- cold air intake?
- 1998 dodge dakota
- lift blocks
- Planning a swap
- door hinge removal
- Fogs
- Pph
- PO720 code
- MIL light coming on WTF?
- Head gasket or Tranny took a crap today i think.. WOOT!
- how strong is my rear end?
- Parts for sale all must go
- cleaning a block
- 1999 Dakota RT Parts
- Exhaust problems, HELP
- Superchip Flashpaq vs. Cortex
- factory stereo
- New
- New Part!
- center console, rims, o2 sim, n2o, taillights ect for sale...
- Replacing Inside Door Handle
- engine swap 3.7 to 5.9
- Overhead Console
- For those of you looking for a Lift...
- Help! Front Drivers Seat Broken! Backrest doesnt lock
- transmission and air conditioning problems?
- Plugs Suggestion 98 3.9l Dakota
- keyless remolt??
- Question about about my headlights,..
- 2002 dodge dakota owners manual
- Turn Signal Assy
- So I got an iPhone...
- MMM Stick...bored video's
- my truck
- tips for my 3.9
- Rims For 98 Dakota
- 98 dakota sputters after it starts
- Headlight Adjustment\Removal How to ?
- New Dakota Owner
- Camper shell
- trailering questions
- I'm trading my Dakota for these
- electrical question & new to the dodge scene
- nominations open
- Looking for the best shock for a reasonable price
- dakota overdrive oversensitive
- headlights now, can you help
- jacks for 4x4
- tb lift question..
- 2000 Dakota power steering pump replacement--what do I need?
- which do you think is better?
- Epic Fail
- Dakota 4X4 thread
- Electronic Brake Controller
- Heater Core
- Need a new transfer case but which one?
- boat with a hemi
- 2000 3.9 has no throttle response?
- its getting there
- Trans Q + power Q
- 2003 Dakota Stalls when making sharp turns
- Quick Suspension Question
- Good upgrade for v6 or v8s needing a Throttle Body
- Stacks?
- Viper Wheels
- Anyone want to buy a
- Vacuum Leaks???
- catalytic converter
- Before and After
- Custom CAI installed...
- What Vehicle(s) Use This Transfer Case?
- Cool exterior mods (pictures)
- dual straight pipes or flowmaaster or magnaflow
- Airbag light goes on when I turn the wheel
- headlights
- Exhaust question
- regular cabs
- brakes
- can i do it hot?
- Grille replacement help
- trany code wtf.
- Fun in the snow
- water pump squeal?
- Need 98 3.9L PCM Connector & Pin IDs
- CarPart4u Test Fitment: Cars Needed!
- Low Engine Temp, luke warm heat and warm a/c
- Hey all. Yep, another noob in need of some advice
- Wiper Blade Sale
- Power Steering Problems
- Off-road Dakota meet, Colorado
- Bumper plans
- Trying to replace fuel filler neck - help!
- transmission problems dealership mechanics are stupid HELP
- 1-24-09 Dak Meet (pics) 56k beware!
- For sale!
- more on lowering the R/T
- Help: Exhaust
- probabally wont be around for awhile
- 1997 Dakota wont shift into overdrive
- Patch Panels
- Cig Lighter Recepticle
- Rims for sale
- P0601- Where to buy new PCM
- Silly question
- Burning Rubber Smell?
- Intermittent Transmission Noise
- Buying a lift, need help
- 2000 Dakota: Scrap It or Not To Scrap It?
- sway bar
- Wheel Spacer Questions
- Maf conversion?
- 3.9L clutch fan
- wow...
- compressor ready
- Taillights and windows done!
- Couple questions
- 98 dual fuel but wont run on Gas...
- After heater core install problems????
- TB modification
- V6 or V8
- Finally reuploaded an album
- Feburary TOTM
- $1,265.00 front end work!
- Heater not blowing hot enough, need some hints.
- Rattling when shifted into drive, '97 Dak
- uhg me and the girlfriend broke up.
- Dakota cranks but wont start?
- New front wheel bearing going bad???!!!
- my dakota that i bought last week is already breaking down
- Hard to start truck due to clutch?
- 01 Dakota 4x4 front lower ball joint removal
- Clutch Adjustment?
- transmission sylnoid
- new to the forum thanks for help
- motor or tranny? i dont know.
- 2000 Dakota V6 RWD will not turn over
- 2000 dodge dakota over heating
- Wiper Cowl Installed (for fitment)
- What size tires?
- question on wheel bolt caps.?
- Lower ball joint question
- dakota ran ok, replaced plugs & wires, now wont start!
- Rim Centering Rings
- rear axle
- Going to San Antonio Jan 31st. - Weekend
- HID, xenon, or silverstar ultra bulbs?
- Oil treatment
- Newbie has rear bumper question
- Rough Start
- muffler help
- '97 Sport 3.9L V6 Auto 2WD falling apart and need serious help
- Growling sound when turning tight (rear end?)
- New Seats and SS Wiper Cowl (pics)
- Ipod or mp3 control
- interesting set of CEL's....
- any TransGo issues
- Heater Blower Motor Resistor Wiring Connector
- 01 Quad Cab 4.7, 4X4=0, Help needed
- good stuff on ebay... superchips
- loud clicking - ujoints?
- New Look!!!
- 3.9L upgrades
- Stiffer leaf springs.
- 4x4 won't shift question #2
- im bored.....and i need some info
- tow hitch question.
- 4x4 won't shift properly
- 1997 dakota transmission
- DROP KIT INSTALLED..pics
- 2001 Dodge Dakota starting issues
- 1998 going dead immediatly after starting
- Transmission trouble. need my truck help!
