PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Need some help quick tire flew off
  2. transmission test port?
  3. more proof that our trucks are Tonka Tuff
  4. 2004 quad cab V6 opinions
  5. Is this a transmission cooler on my Dakota?
  6. Towing Questions...
  7. Source a remanufactured 2.5L
  8. tune up
  9. Acceptable volt meter drop at idle?
  10. Planning My 408
  11. Heater questions and problems
  12. Quad cab front seat question.
  13. 1999 dakota Front rotor removal
  14. Helped w/ stripped torx bolt on MAP!
  15. Replacing steering knuckle
  16. ABS Light help
  17. 5.9 radiator
  18. A/c on in defrost mode / HELP
  19. IAC to MAF IDEAS!!!
  20. Buying '01 Dakota
  21. Evap Hose Locations Under Hood
  22. Not a dakota. Pricing help
  23. brake issue 99 dakota sport
  24. Just replaced my transmission. NEED HELP
  25. P0456 - Evaporative Emissions Leak
  26. Rapid ticking
  27. California vs. Federal Emissions.
  28. Cold start STALL erratic/low idle
  29. Aftermarket Rims
  30. 4.7 Engine Build-up
  31. factory tweeter replacements?
  32. Question is there a difference between AT and MT nv231d transfer cases
  33. New Tires any suggestions
  34. No oil pressure and loud knocking
  35. Driveshaft or U joints?? HELP!
  36. New to the dakota idle problem questions?? help!
  37. in need op a part or the number for one
  38. bigger brakes stronger hubs
  39. UhOh! Lowering a 4x4 qc.
  40. Would like some input on rear bumper design
  41. Computer and Wiring Questions
  42. EVAP Leak P0442 and P0455
  43. which brake line fittings are where?
  44. 01 4.7L quad cab stalling issue
  45. 1999 will not start in park
  46. Not starting!! Need help!!
  47. Speedomoter not working
  48. Dimming Parking Lights
  49. Central Timer Module
  50. New to Mopar, First Dakota, Questions
  51. Break Line Failure
  52. Passenger Side Floor Board Keeps Getting Soaked?
  53. 2wd to 4wd questions
  54. what gears?? 373 or 390??
  55. SCT and California Smog
  56. 98 Dakota 5 speed no clutch
  57. 3.9 won't start
  58. Infinity system and adding 10's
  59. overheat then no start
  60. Evap leak code
  61. Big Mikes 98 Dakota 2.5 Reg Cab 2wd Build Thread
  62. Lost 4x4 after muddin 2001 DAKOTA SPORT
  63. 4.7 to 5.9 tranny question
  64. cylinder 1 misfire code
  65. 285/75/16??
  66. hoses in general 2002 sxt
  67. Help from the 4.7 guys
  68. homemade lift kit?
  69. Negative cable Ground Stud nut size
  70. cherry bomb advice??
  71. Sway Bar End Link Extensions
  72. Transmission help - 97 dakota 4x4 5.2L
  73. Installing center flip up seat (bench) 2004
  74. Lower Control Arm Bolts Help
  75. 1999 Dakota sport speedometer not working
  76. is 255 too hot??
  77. Learning from Mistakes, 4.7L QC 4x4 automatic build
  78. Need Muffler Advice
  79. 2000 Dakota Replacing Clutch Hydraulics - PLEASE HELP!!
  80. A/C clutch not engaging
  81. Dakota rear differential
  82. Mechanics I need help...Again lol
  83. lean, really lean, or stupid lean?
  84. Missing cab mount bolts?
  85. Mopar Performance PCM
  86. Air bag light & no cruise
  87. New computer, runs but backfires.
  88. Gap Betwwen Torque Converter and Flexplate
  89. Cat.....
  90. Crankshaft sensor swap! NEED HELP
  91. 01 4.7 Heat to 210* stopped, 200* on hwy?
  92. Crankshaft Sensor?!? could it be??
  93. Radio problem
  94. Waterpump mess up
  95. 01 Dakota Not Gettin Any Spark!!!
  96. 98 Dakota cummins 3.3 build
  97. electrical problem
  98. why is my truck eating coils?
  99. 01 Dakota WONT START!!
  100. Window cycle problems
  101. signs of ball joint or ???
  102. Getting the brake bleeders loose??
  103. Dakota Won't Start
  104. Transmission from a durango into a Dakota???
  105. Shuddering on take off.
  106. New Exhaust System for 03' 3.9L
  107. ABS and brake light on
  108. 4x4 problems
  109. Before you post
  110. 2000 dakota 3.9 5speed p1389 problems
  111. Harmonic balancer & Seal Dakota 5.9
  112. Need help ASAP. Cam chains and timing issues.
  113. Welded water pump?? REPLACED!!
  114. what if I deleted the CAT
  115. QUICK help needed!!
  116. Tires for the ol' Dakota
  117. Transfer Case Gasket Question
  118. 98 dakota repower have some questions
  119. Handle to engage 4x4 disconnected
  120. P1740 Code Bite Me AGAIN
  121. 3.9 power steering pump removal
  122. 1999 dakota
  123. Tire Decision Help
  124. Engine Swap
  125. Rear wheels locking Not ABS Related
  126. That annual visit...
  127. P1740 code update
  128. Need Help before my mechanic breaks the bank!
  129. My local dealer is a joke
  130. testing map sensor
  131. 03 Dakota 3.9 stumbles
  132. No Radio sound, 1998 Dakota
  133. 02' Dakota 4.7 motor hesitation shifting to drive.
  134. Durango Springs in a Dakota qc
  135. No Overdrive after Engine&Tranny Reach running Temp
  136. Dakota quad cab leaf Springs
  137. Leaf spring interchangeability
  138. Well,..You guys said it...
  139. downstream O2 high voltage
  140. map sensor
  141. 04 Dakota 4wd auto clicking
  142. Bad Rack, worn bushings?, 2 brand new tires, Toast...
  143. Popping noise in front end
  144. Need Help/Advice 2000 Dak. 5.9 4x4
  145. Dropping?
  146. Squealing from accessory belt area
  147. oversize radeator?
  148. either bad wiring/ground issue
  149. 98 DakotA Overheating
  150. best performance upgrade?
  151. First question lol. Leafspring bushings help.
  152. Looking for center seat 04 dakota
  153. lifting recommendations
  154. Speedo not working
  155. 1999 dakota 5.2 4x4 total rebuild
  156. EVAP and O2 Heater Emissions monitors not ready
  157. Fluid on rear tire?
  158. chip vs. programmer?
  159. 2002 dakota: loss of power/gas smell
  160. Can crankshaft position sensor cause miss?
  161. manualtrans stuck in 2nd gear
  162. Clutch Replacing help
  163. 2004 dakota seat question
  164. fsr57
  165. Prestone smell in cab
  166. Noise coming from trans/driveshaft
  167. using oil or leak?
  168. 2.5 Timing off by a bit, cant adjust?
  169. Mystery issue
  170. 04 dakota console?
  171. 440 engine swap
  172. Complete rebuild $ question
  173. Paint Touch Up
  174. Steering components
  175. My First Engine Swap
  176. p0499 purge control solenoid circuit high
  177. Dakota overheating badly
  178. drivers side window fell need part #
  179. 99 dakota shifting issue
  180. Heater problems
  181. Anyone run 275/60-15's on a 2WD?
  182. Intermittent AC problem
  183. Door lock cylinder replacement on 2000 Dakota
  184. Transmission question
  185. allmost stalling
  186. What changed between '97-'99 and '00-'04?
  187. She's hurt!
  188. 4th gear
  189. Steering Shaft
  190. 2 Annoyances I cant stand anymore.
  191. Park idle surges?
  192. 4.7L towing mpg
  193. 3.9 Gasket & Seal Replacement
  194. 2000 dakota front axle pinion leak
  195. Engine light on for 6+ years
  196. 180 plow
  197. What size r the 3 tailgate bolts on 04 dakota
  198. 1997 Dakota Stalled Guages Won't Work
  199. MAP and TPS Voltage Readings
  200. In Need of a good tuner person
  201. 5.9 into 3.9 swap
  202. Transmissions, Gearing and RPM
  203. new doors
  204. Sway Bar Lube
  205. throttle body spacer
  206. Main Beam Dash Light
  207. Comp Cam Ideas!!!
  208. Getting height to my 2001 quad cab
  209. 1999 Dakota 3.9 idle issue
  210. Transmission questions
  211. O3 dakota transfer case problems
  212. $150.00 Sound System....
  213. Malfunction Light Indicator
  214. help!!!
  215. Rebuilt tranny shift linkage won't budge
  216. E3 spark plugs in a 4.7 2004
  217. 4.7 more power and better gas mileage
  218. Best sounding replacement muffler 4.7 stock exhaust
  219. I've got trouble in the rear!
  220. Are these good headlights?
  221. worth rebuilding Leaky Rack & Pinion??
  222. Lighting options '03 Dakota
  223. Turn signals not working
  224. whistle/squeal
  225. 99 4x4 dakota 5.2 auto ticking
  226. ABS light and brake warning light
  227. Hemi swap? SERIOUS TOPIC
  228. front axle questions
  229. Reprogram courtesy light on '01?
  230. back glass water leak
  231. apps and computer programs
  232. 3rd Brake light reverse not working
  233. A/C condensation flooding in cab???
  234. High Speed Noise???
  235. 3.9 to 4.7 or 5.9 Swap... Save My Dak!
  236. Front Blinkers
  237. axle cv joints
  238. What's your Dakota's current milage.
  239. Let This Be a Warning
  240. No oil pressure after head gasket replacement
  241. 1998 Sport 4x4 5.2 V8 engine misfire
  242. A/C leak
  243. hx35 on my 5.2
  244. Update 99 5.2L Dakota Battle
  245. Intake Manifold Question
  246. Transmission Compatibility
  247. instrument cluster lights
  248. Anyway to pull airbag codes?
  249. ABS light and code C1095
  250. 01 Dodge dakota says "no bus"
