View Full Version : 2nd Gen Dakota Tech
- What does this mean?
- FS:incomplete Dodge Dakota factory tonneau cover LeBra 6.5 box
- Drag that shyt
- Engine Code P0420 What does it mean?
- What mods are there to do?
- Bad grounds
- 3.9 club cab and towing?
- 2003 dodge dakota 4.7 aftermarket trans cooler
- sale! buy my stuff so i can fix my bike!
- New Bumper Finally on!!
- truck update
- Transmission shift issue
- Need muffler diamater sizes plz.
- Oil Consumption?
- time for new engine
- rear end rebuild
- Dakota front end info
- Air Conditioning - On all the time w/ defrost?
- seats
- code questions.
- A/C problems
- How much is my truck worth
- Snug Top
- 7 Days!!!
- Another over-asked question
- Spindles 97-98, 99?
- Which cherry bomb?
- Tint Question (pop-out windows)
- Help needed, Electrical problem
- dakota of the month!!! Vote Now!!
- Window regulator help needed.
- New, stupid 2000 Dakota owner...
- Replacing electirc window regulator
- 318 numbers
- New Dak owner, please help.
- Dissconnecting door latch handle -01 Dakota
- 02 transfer case clicking???
- Rear bumper parts
- fan clutch threads
- Power bleeding brakes
- As you all may know...
- front brake pads
- heat/ac fan
- Jerkey Shifting
- Transfer case!!
- Looks like I'm doing a head gasket
- just put my new tires on with a few pics
- New semi-stealth audio system
- Sirius for 2004 Dakota Quad Cab
- 1st generation to second generation engine swap
- maybe make this a sticky. Solved my transmission problem check your truck
- Truck Tool Box
- New to the forum with 2004 Dakota 3.7L
- exhaust for 3.9L v6 ram.
- 2 wheel or 4 wheel abs
- 2nd Gen Dakota - Spice up your signature...
- Need door lock advice
- Again..Looking for Max Tire Size w/NO Lift
- Cannot find Coolant leak?
- spacers
- is this true?
- Mopar Factory Locker (trac-lok) for sale, brand new!
- this if for the dakota gurus
- motor mount ?
- 2000 dakota a/c problems
- oil pressure drops at stop
- IS there a easy way to stop squeaky suspension?
- new guy to the board need some help please
- Any body got some pics of there cb's?
- and so it has evolved
- Where is the crankcase breather?
- Straight pipes?
- Will this tranny work?
- Odd squeeking noise only in reverse
- Front Differential leaking
- AHHHHHH!!!! what is going on???
- Rear wheel bearing
- question about fan clutch
- Superchips $175
- 5.9 or 5.2 lt engine
- New Wheels
- Just for fun
- Yet Another "Wheel" Squeek Diag needed
- AC/Heat Blower motor
- Tire Size
- The UPS man and the click of a mouse
- Air blowing out vent, floor, and defrost
- '02 Dakota climate fan problem
- I think I just screwed my tranny....
- brake fluid leak
- ABS & Brake lit
- Magnaflow Cat-back Exhaust System video
- Rollin in Red
- 3rd Gen Dakota seats in 2nd Gen Quad Cab
- What would I need to do...
- Join the TX Truck Club!
- Is my fan clutch bad?
- Used Superchargers
- 2wd tire question, again!
- SEAT PROBLEM 40/20/40 back rest wont stay up
- Dodge Dakota Radiator...
- what size motor fits
- annoying noise
- Dakota Towing
- Water pump help
- Bank 1 misfires
- Front disc brakes 97 Dakota
- Transmission fluid change
- Drum brake issue!!
- i lol'd
- AC cold then hot then cold help
- rear axle shaft seal
- Disc brake conversion?
- Car Alarm
- HELP!!! Can't find a part...
- Want to paint truck
- torsion bars
- Recalibrate Speedometer for New Tire Size
- 9 or 10 inch brake drums
- Rubbing Sound Coming From LF Wheel
- Should I re-gear??
- Brake issues
- 97 Dakota brakes
- Driver's Side Rear Tail Light Failure...
- 2004 QC 3.7V6 Manual 4x4 Shift indicator light
- p1756 question
- Cold air intake plz help
- When things get to hot
- help diagnosing noise
- 2003 Shock Question
- 2000 Dakota--full of hot air
- Stereo removal help
- Tranny fluid change.
- shaved door handles
- Center Console DIY
- Looking for a Temp Cab top cross bar.
- CTM Issues
- Blower only works on 1 speed
- Need 2000 Non Security 5.9 Fed PCM
- Clicking from front wheel
- help
- Im sitting in a parking lot as I type this
- max weight I can carry
- Suspension
- spray
- Any Florida residents?
- overdrive problems
- lifting a 2003 3.9l 2wd dakota
- looking to find a specific tonneau
- Help me get this paint off my truck
- Change transmission filter/torque differential bolts
- Liftting for newbies
- Viper engine swap???????????
- longtubes + emissions testing = FML
- Axle, Rear, Corporate 9?
- 3.9 to 5.2 swap compatibility question
- Control arm bushings question.
- how long do rear drums last??
- oh you know!! its just whatever
- Help! Tailgate won't open!
- front hitchs?
- Adding Power Windows/Door Locks
- J'ai Fini!!!!!!
- lost a dodge mopar tonneau rail, replacement?
- FS: dakota mud flaps
- Best muffler for a 3.9
- Dodge Dakota
- 2000 dakota quad cab
- v8tb, v8cable, procomp intake, other stuff FS
- passenger side window control
- Thinking of buying a '98 Dakota Sport
- blowing the 30 amp ign fuse
- "Build" thread
- catylac converter help!
- what rad fits a 2.5?
- water pump
- What transmission do i have????
- engine swap questions
- Dodge Dakota Speakers-Help!
- 98 dakota slt keyless entry
- Removing the blower motor
- question about overdrive
- Trying to investigate creating a Dak 'PreRunner'
- blew the rear end...
- Electric fan temperature switch
- Diff fluids
- A tribute to my old dakota
- Help! I need your opinion
- Wireing harness question
- Cold Start Issue
- Any advice on installing tie rods?
- Spindle/hub question.
- New Pics w/ new Nitto's (56k warning)
- Strange Problem with Scanner
- Lowering 2wd 03 dakota
- rimz
- Timing 2002 Dakota 3.9l
- Replace Engine
- I need some help please
- odometer stuck@ 120
- Please help me out transmission and A/C problem
- Problem with A/C vents!
- Solid axle swap
- Surging Engine
- A-arm bushings
- 03 dakota 3.9 starting and running problems...HELP PLEASE
- where the hell is the tire jack?
- Door trim for 99 dakota not sure what its called?
- Wheel Offset
- what are you listening to?
- clock spring? i hope not.
- Odd noise
- heater/ac controls
- Anyone need a canopy?
- 4cyl swap to inline 6cyl
- ready to blow up my '00 dakota
- throttle body spacer and CAI
- wierd problem
- 01 4 cyl clutch replacement? Best place to buy?
- Torquing specs: Ball joints, control arm
- Locked dragging front brakes///Help
- Ok, Read this post... or else....
- ok so im seriously considering this
- Does anyone have experience with this cold air intake?
- 10 minutes
- overhead info display
- i got new muff
- Supercharger For Sale
- its starting...
- Air-----bags.....
- pulley size power steering pump?
- How are these things?
- what do you guys think? legit?
- Automatic Tranny Flush - How's it done?
- 2003 Dakota Questions
- Might be trading the R/T for a ....
- Inlet size
- Place to buy Inner tierod?
- 98 dakota with dead gauge cluster
- 93 prelude VS. 00 Dak R/T
- parting out 01 quad cab
- Homebrewed Air Intake
- Went to the street races last night
- How "free" should the front wheels be on a 2WD Dakota?
- looking at an R/T, CARFAX anyone?
- Steering wheel feedback?
- Drum brake question
- 2000 Dakota SLT
- Misfire
