View Full Version : 2nd Gen Dakota Tech
- Sqeeking Noise
- Cant find an answer!
- Flowmaster 40 Muffler + Seafoam Treatment
- Problem w/ Anti-slip Differiential
- 4.7 swap
- alternator compatibility
- washer nozzle broken
- Bump Stops
- 5-speed driving for mileage
- 5.2 rebuilt-oil in 1 valve cover-low pressure?
- Flowmaster 40, 40 Delta, 50 HD?
- Lowering Kit?
- 02 dakota 4.7 overheating problem
- '00 Tranny swap question
- Finally Got my Body lift & shocks put on my truck !
- Unpowered Cig lighter?
- Differential Help!
- FS: DDM Tuning 8k High/Low HID Kit 9007 Bulb
- Caught them in a lie!
- Batman Sighting!!!
- 97 Dakota No Start HELP
- Amp installation
- bellhousing/tranfer case separation
- Someone Help, PLZ PLZ PLZ HELP!!!!
- yay new headunit!
- 99 dakota 5.9 RT trans?
- My work on my 2001 QC
- Please help..truck won't stay running after TPS calibration.
- What is the thinnest tires that could fit stock SXT 16 inch (7inch width) rims
- t-case nob
- How much does insurance cost on your Dakota?
- New to the forum! Afew Questions...
- Hooking up Trailer brakes w/ controller. Do I have tow package?
- can i get a little help with my new 00 Dakota?
- European Headlights- best?
- 99 dakota tranny
- 99 dakota fuel
- new wheels and tires
- Jet Accu-Speed Calibrator
- 318 engine problems
- Hooking up Siruis into Stock 2002 Radio
- 98 Dakota Rear Brakes
- So yea dry rot sucks
- 97 v6 dakota overheated and wont start!!
- new daily driver
- Wits end with Stalling 97 dakota any help?
- Help register truck
- Water damage
- Removing your cat
- ummmm....
- stock infinity headunit
- Drum brakes
- Driveline Lock-up Scary Stuff and highway Speeds!
- Locking Steering Column
- 98 Dakota Tran issues
- O2 sensor removal
- peeling clear coat
- nv231 transfer case question
- Quick headlight Q...
- 5.9 exhaust advice?
- No brake lights, hazard or turn signals 2003 Dakota
- WTB some slotted front rotors for a 1999 5.9
- Tuners! Clear Corners!
- engine/transmission combos?
- ye or ghey?
- Headlight mods.
- Purchasing Dodge Dakota, towing questions, former owner
- Pillar mount gauges
- HELP! Overdrive kicking off
- split hose
- Lift Kit for a 2001 Dodge Dakota
- Exhaust question
- 22 gal tank?
- Bosh vs. Denso Alternator. Important?
- 02 ABS issue
- Alternator, Battery or Voltage Regulator in Computer?
- Voltage Regulator, Alternator or Battery? 1999 Dakota
- Instrument Cluster
- question about 4.7 dakota (gas mileage)
- wheels
- People amaze me...
- cam??
- Sway bar bushing options
- 99 dakota flywheel
- Non R/T Package Durango with a 5.9
- Good deal or no?
- need some help with motor build
- Djm 3/5 inch drop ?
- 99 dakota 3.9l at transfer case
- broke torsion adjuster bolt!
- What R The Differences Between Dakota 4.7 n Ho. 4.7 In The Jeep Overland
- Cold start trouble
- got some cragars
- rear pinion seal
- Check engine Light
- Bfsc?????
- REAL cowl induction hood
- Radio has power but no sound?!?
- Turn signal woes
- 2004 dodge dakota car stereo question
- Looking for 4.7 manifold upgrade info
- Truck whips back and forth?
- No heat on low fan
- 97 Tranny Issues .... Need Assistance
- Having trouble selling 2000 Dak
- I wish I was retarded !
- coolant leak help
- Where is the tach wire?
- spindle/key lift for my 02 dakota
- electrical gremlins
- 1.7 Harland Sharp Roller Rockers
- killed the 42RE...
- tranny problems code p0733 and p0734
- another fiberglass part in D Kota
- Turtle Wax ICE question
- 99 Dakota 4x4 Front axle
- Front Brakes Locking Up PLZ Help
- What a thing to wake up to
- Aftermarket Air Intake/Filter
- differntial problem
- 03 Dak with odd issues need ideas..
- please help 99 Dakota
- 318 Tranny issues
- 3.9 engine miss
- engine chatter in the cold mornings
- 98 Dakota Club Cab 1/4 Window Replacement
- Brake adjustment...
- Dash Problem
- 2001 4.7L Trouble starting hot
- '01 Factory Stereo ID
- Leaking coolant/water from somewhere...HELP
- 32x11.50 Goodyear MT/R's on 15x7 Dakota Wheels For Sale
- Whats the best - Tires?
- tire size
- will this tranny work?
- 4.7L Valve Cover Gaskets
- Got manfiold leak partially fixed. lol.
- mechanic says 2004 dakota computer 'locked down'
- back seat subs...
- Replaced brake flex hose and now I have leak
- coolant leak at timing cover
- Vibration when in gear
- TPS problem P0123 high volts (please help)
- 2001 Dodge Dakota 4.7L 'Clattering Noise'
- anybody want subs? pretty cheap
- headlight bulb smoking
- What do you use in oil changes?
- Old truck new user 1999 Dakota
- DOTM Oct
- Plenum Gasket Bad?
- Is high mileage bad?
- 2001 Dakota 4 cyl clutch install... torque specs?
- where do i dig??????
- Help please from the UK
- 97 Dak rough idle..sometimes..suspect MAP
- Tires
- CEL Code P0601
- high idle?
- oil pressure/dip stick overfill?
- 4.7 HO feasibility in 4.7 hole?
- 5.9 Magnum Ticking...
- 99 Dakota front shocks
- Header Question..
- 01 dakota problems
- Rear lowering very hard
- '00 4.7L 4x4 cold start & shifting issues
- ABS valve, sensor and controller
- Valvoline Max Life ATF
- steering shaft
- I need a favor...
- noob questions about dakotas
- Auto door-locking feature
- *Help*2001 4x4 Sport Quad cab 4.7L v8*Help*
- Winter projects
- rough idle when stop/ 99 dakota
- 01' 4cyl Dakota Idles Very High
- Engine rebuild question
- sticking in park...
- abs pump
- DOTM Oct.
- What gear lube for the 8.25"?
- Aussie Lockers
- what dumb things make you fail inspection
- level sxt
- brake line booster-seafoam
- question about timing cover
- 02 Dakota TCCM
- shocks? speakers?
- 1999 dodge dakota eliminated AC belt
- 5.2 fuel problems
- Jet chip update
- 01 2.5L clutch repair
- Looking at getting some Cragars
- Radiator Air Lock Question
- 2000 5.9L ecu/nv3500
- Dropping an R/T
- 2003-2007 vs. 2008 intake manifold upgrade
- Complete Overhaul 2004 V8 Dak... 3 days away.
- Power Steerin Pump Problems
- how to replace ball joints on dodge v-6 2000
- Sport Slow Revs
- Need help with wheel spacers
- KRC performance throttle bodies
- Injectors
- gen2 quest
- 2004 Dakota tough to steer!?
- custom tunes
- 97 Dakota Help
- nicest dodge dakota ive ever seen.
- Need help finding this thread
- Fog light mystery...
- Morning misfire....Has me baffled
- 99 Dakota Transfer Case
- Wiring Issue
- Tire size change?
- Need Help
- 5.2 to 5.9l swap help please witch harness and computer to use
- Airbag Light
- Black Taillights?
- Help fuse
- Taurus fan on 97 5.2
- I need your help R/T owners, please
- question about getting bigger tires
- A good flex or not?
- P0133 gone -- P0171 won't go away
- mod tips .. help
- Resetting gauge cluster
- Flashing headlights
- 97 Dakota with 3.9 ltr 6--Oil pressure gauge
- halo head lights in the winter??
- Any of you dakota guys need some BGS MT's?
- ok im stumped
- hazard lights
- More electrical...
- Going to remove exhaust manifold on each side. Need some pointers.
- Reset odometer?
- Frustrated
- Bad Synchros?
- The bogy beasts! whadda ya think? *pic*
- Where is Bank 1 sensor 1 on 2000 Dodge dakota
- TB's for sale - lower prices
- Headlight lens removal?
- Need some intake manifold advice.
- 2008 intake manifold
- Wheels
- max tire size with 2in leveling kit
- need some info
- Ball joints...
- 3923 or 3924
- Chevy Ad In A Dodge Forum
