PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. interor ????
  2. Bad U-Joint Symptoms and DIY Repair
  3. 3.9L auto 2nd to 3rd shift problem
  4. Clock Spring Issue
  5. Help please turn signal problem
  6. just a few pics
  7. 2001 Dodge Dakota 4.7 HELLLPPP PLLLEEASE
  8. O2 sensors installed - bugger!
  9. body parts
  10. engine dying
  11. sport bumper on a non sport truck?
  12. Best thing to get tar/road grime off?
  13. Anyone else do this?
  14. Proformance Chips
  15. Guage cluster bad?
  16. made a tire carrier out of boredom and no room in the bed
  17. Average Miles for Dakota?
  18. which tuner???
  19. Help wierd vibrating noise
  20. need a few things explained
  21. Please help wiring problems
  22. Power sliding rear window?
  23. speed sensors.
  24. Rims
  25. Please HELP!!!!
  26. wont start help please
  27. Mechanical Oil psi gauge install (pics)
  28. '98 Dakota keep dying
  29. ABS/Brake lights
  30. How do I know if I have LSD?
  31. 93 Dakota Ignition Issue
  32. Fail Safe t-stat warning
  33. underdrive pullys for the 4.7l
  34. How to figure out your HP (approximately)
  35. 5.2 running just a cat(vid)
  36. kc lights
  37. A/C
  38. 98 3.9 not shifting after tranny tune up, opinions?
  39. Who likes mud
  40. Quick transfer case fluid change question
  41. Finally took some audio/ video of my truck
  42. New Alternator
  43. stock shackle length for 2wd
  44. High flow cats
  45. Traction question/ plz help
  46. 2003 Dodge Dakota oil pressure issue
  47. Recent purchase need help
  48. How do you properly adjust the fog light beam height ?
  49. 1997-2004 dakota parts manuals
  50. Oil Pressure
  51. shackle lit help needed
  52. Update for 3.7 V6
  53. Please help me understand...
  54. Bearing of AC clutch problem
  55. What is the Smell?
  56. no start issue
  57. what makes the 2003- 2004 dakota lift different?
  58. Timing cover/front seal oil leak
  59. New bike... with something in the bed
  60. Windows not rolling down.....
  61. pinion type 98 dakota
  62. Dakota Interior = Durango Interior?
  63. shifter
  64. Plugs
  65. Removed my clutch fan- quick question
  66. iac maken my ideal high?
  67. Painting Six Lug Rims
  68. P S Rack hesitation
  69. rear axle fluid
  70. Anyone had the extended PID for the IAC?
  71. Replacement for the 42Re
  72. 3.9 parts
  73. A few things...
  74. Best Spark Plug?
  75. $1300 Part??? Do I Need It???
  76. amplified bass tube question
  77. Leather bench seats?
  78. has anybody installed add a leafs?
  79. I need more ooooMPH
  80. Well,.. My Trans finally went south,..
  81. 04 CC 4.7 fuel smell?
  82. steering wheel pop.. how to fix it??
  83. stumped,
  84. 2k 4.7 would not start but all electrical normal?
  85. P1281 problems
  86. problems with stalling
  87. looking at a scsb with 5.2 stick
  88. Big Bore TB
  89. Please tell me how to remove the clips on the fuel injector wires.
  90. got another v8 dakota, its a fixer upper tho
  91. sensor's today,after work hope it helps
  92. Where do I recharge my A/C?
  93. Deal or No Deal?
  94. 04 4.7 electric fan question
  95. WTB: R/T Rims
  96. 97 dakota won't start after running warm
  97. Injector problems
  98. engine shuting off
  99. Body side moldings
  100. Shifting issues (non transmission)
  101. 4.7L fuel mileage?
  102. Help!? Headbolts
  103. blower motor
  104. 'Quiet' freeflow exhaust?
  105. 02 sensor questions
  106. wheelbase question
  107. 1999 Dakota Manual COLD AIR INTAKE QUESTION
  108. headers
  109. dash looks like a Christmas tree
  110. P code problem
  111. Tried to get dirty....didnt work enough...had fun tho!
  112. Questions about new lift
  113. lookin a cam
  114. WANTED: Over The Rail Bedliner
  115. Yet another "low heat" thread!
  116. Steering Shaft U-Joint
  117. Some helpful advice for a newb please.
  118. Good price for work done at shop?
  119. blew the speakers
  120. overhead display
  121. 350 swap in dakota.
  122. Issue when accelerating
  123. Losing Coolant
  124. Aussie locker, lock right locker...?
  125. WTF is this?
  126. Please help trouble shoot power steering trouble
  127. HI! New here!
  128. Power Steering/steering.
  129. 44re Transfer Case Fluid?
  130. lift my 01
  131. Power Steering help
  132. helping a friend....
  133. Just shut off and will not start
  134. anyone have a double u-joint front d-shaft?
  135. In need off advice
  136. In need off advice
  137. heater motor
  138. looking for OBD2 port wiring diagram
  139. Need color code for my obd2 port for my 99 Dak
  140. Overdrive stuck in off?
  141. 99 3.9 gaping for plugs
  142. code p0152/driving issues. 3.9l v6
  143. Speed Sensors n Fuel sending units
  144. 97 Dak 5.2 check engine, and shaking...@^$*&@&
  145. P1682
  146. HID's on a Canadian Dakota
  147. bad cat symptoms
  148. Help - Problem after battery change
  149. got my cat back on today!!!
  150. Problem after battery change
  151. 2000 3.9 V6 Sputtering issue
  152. MAP Sensor-Broken bolt or plastic nubby?
  153. trouble keeping running
  154. need some help
  155. Engine fan help!!!!!
  156. Engine fan help!!!
  157. Upside down shift knob
  158. Adding more to dodge dakota
  159. my latest mods
  160. Fuel Pump Module - What are signs it's failing?
  161. engine knocking and smoking
  162. cleaned the tb and found this
  163. Where can I buy frame mount bushings?
  164. NP244 problem
  165. weird things going on with 04 Daktoa
  166. Low Voltage
  167. 99 stock fogg light size
  168. who all has factory skid plates
  169. 04 Club Cab 4x4 Fuel Capacity
  170. 1999 dakota 4x4
  171. Heater problems
  172. Rear End Gears
  173. 1999 tune up
  174. 04 Dakota, Happy so-far.
  175. AC compressor swap
  176. Transmisson fluid pressure sensor
  177. 2000 Dakota 4.7 w/ a bad rightbank head??
  178. Throttle Position Sensor
  179. 1998 dakota 3.9 2wd wiring help
  180. 6speed Manual Transmission Swap
  181. Transfer Case Part #...
  182. question about oil pressure
  183. 92' 5.2L Swap to my 98 Dak
  184. Missing/lurching at highway speed.......
  185. Need advice on buying used Dakota, what engine to avoid?
  186. Fog lights on with High Beams
  187. Check engine light on AGAIN!!
  188. engine work,upgrades, etc
  189. Trans is done, kind of
  190. 2003 dakota with 4.7 tuner ?
  191. Is the transmission mount easy to replace?
  192. fuel rail pressure drops when engine off a hour or so
  193. a/c compressor into air compressor?
  194. weird coolant dumping
  195. Opinions on 2nd Gen Daks?
  196. Tire recommendation?
  197. 5.2 engine swap question
  198. 2003 Dakota Magnum V6 3.9L dying out
  199. Replace O2 Sensors: Home or shop project?
  200. 2004 Dakota dash lights wont work help!!!!
  201. Floor shifter talk
  202. Electrical
  203. Dakota missing on #3 cylinder
  204. where is the IAC on the 3.9l v6 dakota motor??????
  205. Turn signal issues
  206. truck won't start
  207. Hair line crack in block
  208. Boredom+empty interstate=115mph "video"
  209. screaching noise
  210. Torsion bars
  211. wont start
  212. Ground locations
  213. efan controller
  214. 2000 dakota
  215. Headlight problem
  216. Long cranking before start
  217. mini project
  218. 01 Dak QC HID lights
  219. Mirrors don't fold right?
  220. New Muffler Installed!!
  221. Transgo shift kit.
  222. 06 motor swap in a 01
  223. Now that winter has calmed...
  224. Suspension tools needed?
  225. All those with a SAS please come in.
  226. new tires!!
  227. new plugs and still missn?
  228. I replaced my two pre-cat O2 sensors
  229. New Clutch but loud rumbling noise - Please Help
  230. Door Panel
  231. WTF%$&#*$# Running Rich
  232. LED dash lights
  233. Dodge Dakota will not run after transmission fluid changed.
  234. turn signal blinks fast?
  235. Hurst test....
  236. Fog light Problem
  237. "Kegger" intake question
  238. 2001 Dodge Dakota - Nobody Can Figure Out
  239. transfer case problem???
  240. Cams
  241. 2002 dakota headlight switch/dimmer question and foglight removal question
  242. turn signal wiring
  243. 2K dakota 4X4 steering issue
  244. Power Steering VERY difficult to turn!!
  245. Wheres the Proof- Mods!
  246. Oxygen Sensor confused!
  247. 99 dak transfer case service...
  248. worst luck, other HG is blown and head is warped.
  249. help with suspension problem please
  250. Parts List for R/T
