PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. need some ideas
  2. 98 Dakota - Info Request
  3. Ignorant Mechanic
  4. clutch master and slave cylinder
  5. im a magnet for idiots
  6. Chrysler 9.25 in place of 8.25
  7. '01 4WD engaging on its own?
  8. Central Illinois Daks?!
  9. URGENT
  10. trying to find a no ac belt for a 4.7
  11. throttlebodys
  12. will 15x8 wheels w/ 3/4" backspacing work on a 99 dakota 4x4?
  13. 04 Dak Auto Body Lift Question
  14. converted to LED tails
  15. why won't it stop!?
  16. Truck Feels Wierd
  17. 392 HEMI?
  18. speeding ticket
  19. Dodge Dakota R/T
  20. changed rotors
  21. Serius Radio install
  22. bf goodrich ta km2
  23. ABS light??
  24. Nor. Cal.?
  25. windage tray?
  26. water coming in to the cab
  27. 200 amp alternator
  28. Cruise control not holding decelerating
  29. Custom CAI and Exaust
  30. 4.7 pcm
  31. anyone try these projector headlights?
  32. '02 4.7 Stalls almost immdiately after starting
  33. factory fender flares how much are they worth?
  34. efan hook up
  35. damn truck broke down
  36. v10 in a dakota
  37. those damn 02 sensors.. why?
  38. Electric rad fan problems anyone?
  39. Truck Died
  40. 2002 Dakota AWD???
  41. 4.7 intake manifolds
  42. No More Bog! idle still rough
  43. AC problems
  44. Ball joints
  45. Confused about O2 Sensors on a 2003 Quad Cab, 4 or 5 sensors?
  46. i have a rim problem
  47. Superchip questions
  48. Passing Gear?
  49. my fan
  50. Wheels?
  51. Exaust and Intake??
  52. Superchips
  53. Hoods
  54. Windshield Cowl help
  55. Royal Purple??
  56. Rear Anti-Sway Bar Question??
  57. How Hard Changing Clutch Fan and Belt Tensioner?
  58. Low Fuel Indicator And Air Conditioner
  59. 2004 cruise control problem
  60. Problem with acceleration
  61. Ethanol
  62. gas mileage
  63. mopars at milan 9/01/07
  64. Blown engine
  65. Aftermarket brake options??
  66. Just Doin Some Research.
  67. Serious Overheating Problem
  68. o2 sensor bypass
  69. Instrument cluster problem
  70. Pictures
  71. Pinion bearings WTF!!!!
  72. starting problems
  73. Changing Timing chain and Adjustment...
  74. Have an ABS problem
  75. Truck died No Bus???
  76. Mopar transfer case ATF+4
  77. First Truck
  78. 318 to 360
  79. Control Arm Bushings
  80. 4X4 question
  81. Looking for an R/T perhaps
  82. New style of plugs.....
  83. watchya think?
  84. Bogging out
  85. cam pos. sens. code???
  86. New project (will update as i go..)
  87. air conditioner compressor clutch connector
  88. Oil Filter Placement
  89. Been a while and got a new toy
  90. Adjusting Steering Rack
  91. head bolts
  92. a glass pack on my Glass pack
  93. Replaced Carpet today.. Pics
  94. radio clicking
  95. Blinker fix?
  96. new r/t pics.
  97. power windows and winshield wipers 03 dakota sport club cab
  98. Spark plugs for 99 dodge dakota V8 5.2
  99. NEW GAME!
  100. big problem.. not with the truck
  101. no instrument gauges
  102. dont be like me
  103. tires rubbing
  104. 100,000 mile tune up?
  105. MOVED: Hemi Ram vs R/T Dak
  106. My Tranny Fix
  107. throttle spacer 4 v6
  108. 2000 Dakota - Driver's Side Window Problems
  109. clear corner and taillights
  110. HID's - yes or no?
  111. gauge cluster
  112. Oil life with Mobil 1??
  113. tranny shops
  114. My Two Daks *Pics*
  115. '99 dakota acting REALLY strange........
  116. removing stock air box
  117. 20" R/T Replica Dak Wheels
  118. 4WD Indicator Lamp
  119. pics wanted!!
  120. Please post your R/T Drag Radial 60ft times!
  121. tires
  122. any texas fourwheelers?
  123. neon?
  124. plug wires? problem fixed?
  125. Exhaust questions
  126. 4 wheel drive...
  127. Bushwacker Bed Rails
  128. tank size in 98 dakota
  129. 2004 4.7L Tranny Question.
  130. Speed Sensor location
  131. New Dakota Owner!! What to do??
  132. shocks
  133. audio system
  134. Common Problems
  135. lug nut caps
  136. Front Wheel Squeak
  137. has anyone noticed?
  138. Questions about lifting my truck
  139. Moving into my dorm for college
  140. TIRES
  141. R/T sway bar for sale
  142. In need of some more pick up and go
  143. Creaking, grinding noise while turning
  144. cheap n loud
  145. are 285/75-r17's to big for a stock dakota?
  146. random plug?
  147. Weird shift
  148. Side view mirrors
  149. No Shift out of 1st?????
  150. son of a...threww some codes
  151. AC Problem
  152. lifting a 2000 4x4
  153. Replacing the Cat(s)?
  154. Stock v8 Throttle Body for sell
  155. successful vacation.
  156. 2000 Dakota R/T Mopar Performance PCM for sell.
  157. Blown Motor - Where to Buy a replacement
  158. moparfest new hamberg ontario
  159. cam postion sensor/distributor problems
  160. 601
  161. 2000 V6 radiator fan switch failure?
  162. 3.9 with turbo or super charge it?
  163. Dakota RT Durango RT horsepower?
  164. A/C Acting weird then completely stops working when towing
  165. Key fob programming problems
  166. Looked at a 2002 Dakota and have question
  167. 52mm Holley TB installed (before and after pics)
  168. gear questions
  169. Good old ebay sales: Is this mod real or legitimate? Functional or Fraud?
  170. sick truck needs help
  171. how would you spend $2500?!?
  172. help with fuel leak
  173. 2004 Tranny Problems
  174. New Leaf Springs, is there a difference?
  175. Any paint re-calls?
  176. 4.0 - 3.9 - 4.7 Different bellhousing bolt patterns?
  177. NV3500 to HD or 2WD to 4WD hybrid/combos?
  178. forced induction.
  179. 2001 transmission
  180. cruise control
  181. TRANSMISSION SLIPS TO NEUTRAL
  182. front end clunk and squeek FIXED!
  183. ABS/Brake Light - ABS wiring diagram
  184. locating ac high and low lines 2000 dakota 4.7l
  185. Cool Blue Fogs?
  186. auto tranny cooler
  187. Custom QC Dakota Enclosure and seat 4sale
  188. CEL on, but everything is normal.
  189. water in tank?
  190. my truck is sick help make it feel beter
  191. Engine Cleaning
  192. Check Engine :(
  193. Maybe a little bit taller....
  194. CREEK RUN
  195. electrical question
  196. Just got a R/T
  197. Mopar PCM Possibly affecting transmission shifts?
  198. 4.7L HO Cams and intake manifold
  199. spark plugs
  200. Weakkk exhaust
  201. redline power chip?
  202. No tow package... limits?
  203. A/C fixed, but i have a question?!?!
  204. Factory Driving Light Size
  205. 01 or later TB ?
  206. Positive battery cable $200+ !!????//
  207. 2001 3.9L engine coolant
  208. '01 dakota 3.9 charging system ?
  209. Chopped the bed quarter panel!
  210. Need ground cable. Alternative to $700 dealer harness?
  211. AC Goes to Defrost under load
  212. new pics
  213. 2001 Dodge Dakota Help!!
  214. oil pump relacement help or tips pls
  215. 3.9 2001 engine start problems
  216. 2003 DODGE DAKOTA MANUAL
  217. 2003 DODGE DAKOTA
  218. The Quads New Mods
  219. Valve Covers Installed (pics)
  220. New Throttle Body and 1.7 Rockers
  221. 17 gal to 22 gal fuel tank mod
  222. I did a backflip in my dak!!!!
  223. What is largest tire you put on a stock rim??
  224. hesitates & bogs down @ times
  225. Headlight bracket
  226. Want to see the M1 being cast?
  227. HO 4.7L or not
  228. water on floor - finding the leak(s)
  229. Woot got some new parts (about time)
  230. knocking noise uphill?
  231. QTP exhaust cutouts for my R/T
  232. Lightning Killer Package for R/T??
  233. Looking for these parts.. please look.
  234. Holy wow replacing the plenum gasket is a B$%^#!
  235. 2002 Dodge Dakota HVAC blower problem
  236. 4.7L misfiring
  237. Braker Braker 1 9er....
  238. have you taken your truck to the track? post your timeslips!
  239. leaf springs
  240. New here with questions
  241. Is My Motor A Real Sludge Bucket?
  242. TPS Mod on a 4.7... What To Expect
  243. Interchangeable Parts
  244. Engine rpm
  245. discontinued SRT-10 Rams?
  246. Rear end gear ratio?
  247. abs brake light problem
  248. HELP! 02 Dakota Lower Control Arms
  249. bed quarter panel chopping?
  250. Installing trailer brakes in truck
