View Full Version : 2nd Gen Dakota Tech
- vacuum
- stock amplifier location??
- I NEED HELP!!!!!!
- picture avtar thingie
- FREEZE PLUGS LEAKING -ANYBODY KNOW ABOUT?
- bigger tires
- gas question
- 1/4 mile et, mph..
- Remote problems???
- Oil pressure jumping around, some ????'s
- I was wondering???
- tornado air flow
- High nitrogen count during MD emission test
- Installing foglight override
- How much lift can I get with Torsion Bar Cranking?
- Oil Change and Weird Problem
- bought used 04 QC 4X4 3.7v6. how to tell if it has limited slip or not.
- June Ride of the Month Voting!!!!!!!!!
- Speaker sizes 01 dakota
- Cab Filter?
- 97 dakota 5.9l trans.
- home made CAI
- 97-03 dakota extended cab sub boxes(fits under rear seats)
- transfer case
- Transmission Leak - Help!
- 2003 Jet chip install question
- What does a bad CLUTCH fan noise sound like
- Reverse Lights Problem
- Disable automatic locks
- New Tires HELP!!!
- 04 dakota 3.7
- Stock Exhaust Question
- do all 2nd gen R/T have alluminum heads?
- lift
- Trailer Hitch Install Issue!!
- 2000 Dak Quad Cab, V6 w/ water leak
- Swaybar bushings - Fixed!
- exhaust
- High-flow cats and exhaust tubing size
- A/C Evaporator replace
- Tire Question
- 2001 Dakota will not crank
- o4 dakota for sale
- Swap's
- highschool kid... looking 4 a truck..3.9???
- Sudden Power Loss? Can anyone help me?
- component or full range
- 5.9 or 4.7 Quad Cab help for new guy
- AC Help
- Supercharger For Sale
- 97 wont fire
- 97 dakota remotes programing
- bosch plugs
- question about nitrous
- mods
- rear diff question
- xaust questions
- What trans does the 3.7 have?
- Need a pic of a blue regular cab!
- wiring help
- Improve Gas Mileage
- Reliability?
- New to Dodge...
- What lights for Clear Markers??
- Great ride!
- shocking question
- rear leve springs
- Trailer hitch??
- Can I Flip The Rear Leve Springs?
- start-up squeal
- NEED SOME PICS PLEASE!!
- 3.9 ticking!! PLEASE HELP!!!!!!!
- 1997 A/C issue-coil?
- Rev's go drop when turning the wheel
- tail light cover removal
- Looking for a PCM
- Power Fuse
- 99 v-6 no start
- Power Steering Problem??
- I am out of ideas I really need help
- FS:20" KMC Stealth
- dakota r/t w/ nitrous
- 98 DAKOTA BALL JOINTS
- High Flow Cat
- side mirror
- iPod radio interface
- trans coversion
- Wont start!
- New Guy on the block
- Clutch Pedal Adjustment?HELP!
- 1999 5.2 318 4x4_3" Body Lift Fit 33's?
- Rumble in the streets!
- Turn signal
- Cold Weather = Misfire and crazy tach for 3.9L
- window crank removal
- Shock Questions
- Q bugging me
- P0455 EVAP Problem
- 4.7l UD Pulley/Headers?
- exhaust
- Changing gear ratios to increase gas mileag
- new member, please help
- speaker size?
- 00-02 Dakota lift kit
- Removing headlight to change bulb?
- front hub nut
- looking at '03 4.7L quad cab...
- '01 3.9 Dakota Couple Problems
- '01 3.9 Couple problems
- Curious qeustions on 2wd drive dak. trying to be like there 4wd breathern
- 2001 V6 Popping Noise?!
- Engine Noise. what is it?
- PO171 & PO132 help!!!!! Please
- shift kit for dakota 98
- Some questions...
- Brakes
- Dakota/Durango seats exchangeable?
- Which is better Amsoil or Mobil 1?
- Will this work?
- several questions
- new headlights!
- Leaky
- When to do tune-up on 2004 3.7L
- Problem with Fender Flares
- Parking light wire
- Gears
- Will not Idle
- Break In!!
- Engine oil flushing before syn oil?
- V8 swap.
- can a lug nut lose its cap?
- 98 dakota fuel filter
- fuel filter
- Is it possible .. sluggish
- What is that smell?
- clicking noise when moving
- Need advice for pulling a trailer long distance
- FlowMaster Exhaust Good...Bad??
- Front Diff cover for '97 Dak
- May Ride of the Month Voting!!!!
- Transmission fluid cooler for 3.9L questions
- 3.9 magnum exhaust
- Lift Kit
- dakota check engine code???????
- Turbocharging a Dakota
- stupid noise
- I Bought It...Now the Questions
- abs and brake light
- New member with a problem
- superchips supertuner
- Jumping to get Codes
- how difficult would this be???
- 98 Dakota Sport 2.5
- 03 dakota
- Gas tank and fuel gauge
- 3.9... new guy on the block.. questions. thanks
- Need help with codes.
- need help with issue
- Dakota 2002 Problem
- tounneau cover - free or best offer
- lug nut size
- Anyone looked at spray-in liners??
- Dodge Dakota 99
- MPG help please
- pics of interior
- Own a Quad Cab Dakota? Then this might be for you!
- belt
- 95 dodge 1500
- New paint job
- Just wondering...
- K&N Intake...Worth It????
- Blinker doing double time?
- dakota gears
- factory spark plugs...any good??
- Car and Truck of the Month, get involved!!
- club cab
- Headlights
- stupid question
- problems mounting on '01 dakata quad cab
- tune up
- Exhaust
- 2002 Dakota Toneau cover
- 2002 Dakota 3.9L Chip
- 2002 Dakota 3.9L Exhaust
- RoughIdle, no codes. check engine on. Help
- club cab seat
- Exhaust install hell storys...
- 180 Thermostat
- Better Brakes
- Truck Specs
- How much?
- Truck doesnt Idle
- Which exhaust should I go with?
- Whining/Whirring sound , Tranny?
- Battery Clamp Help
- No Heat on Passenger Side of Dakota
- sunroof problem
- 2001 DODGE DAKTOA BRAKE SYSTEM
- Both headlights wont turn on....unless pull high beams back.
- Wont crank over
- 2004 superchip programmer
- New owner needs help!
- Infinity wiring ??
- rough idle in gear, missfire, stumble, etc.
- Limited rev
- check engine codes p0132 p0135
- Tech qeustion on engine fan
- What Is Your Opinion?
- Bobbing (chopping) a Dakota truckbed
- what do i do??
- 2002 R/T Revlimiter help
- Replaced some parts / now runs rough
- Dakota "Chirps"
- poor milage
- Elctric Door Lock BUZZZZZZ
- Anyone got a Dak. this color??
- wheels
- Help Cooling System
- dakota r/t meet
- When to change drive fluids
- Dream R/T???
- recall-worthy rear wheel speed sensor???
- rear width of the Gen 1 same as gen 2
- Front tow hooks
- rev's going down when turning the wheel...
- Changing Speedo Lights
- Fog Light Adjustment
- 5.9 questions
- quick body lift question
- new radio
- Please help me choose headers!
- BAD BALL JOINTS????
- Just bought 01 qc 5.9l atx 4x4-have questions
- Need Opinions: Headers
- Timing Chain
- tb spacers and underdrive pulleys
- Technical Difficulties...
- tune up questions
- Magnaflow hiflow cat
- Rear Defrost on 2004
- 2001 Dakota QC ELECTRICAL PROBLEMS
- Ebay front Grill Guard (good idea or not)
- 2nd row durango for dakota
- club cab and baby car seats
- NOOB post, kinda bulky... questions, feelings...
- 3" tubing for exhaust
- cant find a supercharger????
- How to improve gas mileage ???
- In dash a/c kit
