PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Were to buy steering shaft.
  2. need help/advice
  3. magnum 360 limits
  4. Crappy o2 sensors?
  5. 01 3.9 fuel efficiency
  6. Tires
  7. brush holder assembly order/buy
  8. Funny noise from front end
  9. Installing lift..
  10. Over heating after new waterpump
  11. 97 5.2 falls on its face at 2K
  12. How to replace the power steering?
  13. Clicking Noise next to Battery on Idle
  14. p1734
  15. Manual window problem please help. Pictures*
  16. Mod's
  17. Oil pressure
  18. lumbering idle in drive/stall in reverse
  19. 97 5.2l wont fire
  20. valve covers?
  21. Oil Drip
  22. 1998 dakota no start,no crank!
  23. 99 Dakota Sport NO Heat!!!
  24. Thinking of buying a Dakota! Have questions!
  25. modified 5.9L wont rev out (past 3000 rpm)
  26. Replacing Timing Cover - How long?
  27. How hard is it to change out a wheel hub assembly?
  28. Advice for changing out old coolant
  29. Differential Oil
  30. Shocks
  31. 1997 dodge dakota
  32. trans crossmember
  33. Lower Ball Joints
  34. Ac not blowing hard and it's not recirculation door
  35. CRAZY trans issue
  36. Hissing sound from brake pedal
  37. power steering leak. need help.
  38. Exhaust Tip
  39. Before and after
  40. Intermittent hard start, misfire, and high idle
  41. Exhaust Leak help
  42. Temperature Gauge
  43. EGR Tube/Valve
  44. 5.9l auto trans to manual trans conversion?
  45. 42re issue
  46. how to make my km proper?
  47. Need more power! for 4.7
  48. Rear end upgrades
  49. Fog Lights installed in the SLT package
  50. 285/75/16
  51. Lift
  52. possible alignment problem?
  53. Just got myself a 98 dakota
  54. Viper 5701
  55. Gap between bed and bumper
  56. Top Brake rotors?
  57. OEM Key blanks
  58. does anyone know if there is a dak club in arkansas
  59. Hi lift jack
  60. Injector Cleaning, never heard of this before
  61. Idling issues as in IT WONT! need a lil help
  62. 3.9 Vacuum Lines
  63. Perfect For Working On Our Trucks
  64. '02 Dakota Lift
  65. Overlooked Maintenance Issues..?
  66. 2000 Dak "No Bus" error
  67. black cat customs gauges
  68. 42RE losing Overdrive?
  69. HOW TO: Upper ball joints 04 Dakota CC 4wd
  70. trans question
  71. 2000 Dakota Problem
  72. transmission question
  73. Band Adjustment
  74. Serpentine belt "knock"
  75. speed sensor symtoms
  76. Good ball joints???
  77. 2000 Dakota 4.7 starting problems??
  78. Winter gas, No Ethanol...make sense?
  79. licence plate light covers
  80. Whats the name of this part?
  81. Oil leaking out by fan help please!
  82. No wipers!
  83. spongy brakes, vacuum leak?
  84. 2000 Dakota battery?
  85. lift kits
  86. What shocks ?
  87. head lights and parking lights flicker on off
  88. Blower for heater not working...
  89. v6 to v8 swap
  90. Aftermarket torsion bars?
  91. Driver side Squib
  92. Adjusting torsion bars
  93. Rust question
  94. p0308 misfire
  95. 15/16" rim size
  96. 2001 dodge dakota sport electrical problem
  97. 3.9 issues
  98. Fender Replacement
  99. getting my stuff together
  100. Belly Pan?
  101. 04 Dakota CTM
  102. Compatible Engine Years for 2002 Dakota
  103. Dodge Dakota Tail Lights
  104. 3.9 Wiring problem
  105. Idle/Rev Problems?
  106. 99 Dakota feels like it stutters when it doesnt have a load on it.
  107. Hi all 4x4 ????/
  108. 2000 Dakota 4.7L, code0132, please help!!!
  109. TMR Mod (Sorry)
  110. 2002 dakota 4.7 to 5.7 swap
  111. FlashPaq
  112. Stutter/Bucking ... opinions?
  113. does this look right (wiring?)
  114. Freeze plug diameter/depth/specification?
  115. Need help....Out of my element.....
  116. Crank pulley wobble?
  117. Squeeling front Differential
  118. Front bumper mount
  119. Cost of transmission replacement
  120. heater temp help please!!
  121. Recirculate Cabin Air '99 Dakota Sport
  122. Could this Noise be a faulty Alternator
  123. 3.9 to 5.2 never found my answer
  124. Shifting Problem
  125. Hesitation in Rolling Idle
  126. damned nickels and dimes
  127. Water pump inlet tube
  128. Dakota Problem
  129. Dodge dakota 4 wheel drive problems
  130. Help Me Find The Leak
  131. 3.7 issues
  132. Power splice corrosion issue, what years?
  133. How many miles do you have on your 4.7??
  134. Power locks without power widows?
  135. transmission rebuild complete...but not moving in any gears
  136. Dash light bulbs
  137. 3.7 Spark Plug Replacement
  138. Where to put methanol tank
  139. Fixing a Dakota/Durango "nO bUS" PCM for under $5!
  140. please help i have a SHORT!!
  141. Headlight mounting part/retainer needed
  142. Cheap Dakota Lift
  143. Power steering died overnight?!
  144. Factory Service Manual Question
  145. And so it begins.......
  146. Travel Trailer Towing
  147. Power mirror plug problem
  148. 97 Dakota Unique/rare front cupholder?
  149. Homemade intake tube
  150. Another fan belt question. 3.9 v6 2000 model.
  151. P0303 misfire code
  152. SeriusXM radio, is this one good enough?
  153. Not A Dodge But...
  154. quick trans question, HELP ME PLEASE... I BEG
  155. Replacement? 97 Speedometer w/tachometer cluster
  156. F&R Diff and Transfer Case fluids
  157. Armrest 2004 No Storage
  158. Oil Cycles?
  159. Correct Coil PN for an '01 4.7L
  160. disable the air bag
  161. Help! Engine Shuts Down
  162. How many Miles are you getting on your Transmission??
  163. Difference between 02 and 03 Dakota???
  164. No Bus issue
  165. Fuel Pump Relay Clicking
  166. How hard is it to replace the drivers seat in ...
  167. Heating/Venting issue (Draft in cab)
  168. Radiator Removal/Replacement
  169. 99 Dakota.
  170. best headlights
  171. California exhaust??
  172. Fan control knob has only two speeds
  173. 2002 Dakota fuel efficiency
  174. 2002 Dakota CTM
  175. Biggest tires for 2WD
  176. lights killed battery FAST
  177. HELP, parking brake release broken with parking brake left on
  178. Anyone looking for a clean r/t, here's one! 50k miles!
  179. TPS going out fast
  180. Coil Tube O-ring size?
  181. Ram Hood, grille and headlights
  182. 97 dodge dakota weird noise. need help! vid. included
  183. TPS Question
  184. HELP!!! Exhaust Manifold SNAFU
  185. Diesel Dakota SAS
  186. put new rear shocks on my truck, need front measurement
  187. 97 Dakota front center seat cupholder?
  188. can't solve tps p0123 problem
  189. Radio problems
  190. site to translate engine code from the odometer window
  191. 2002 Dodge Dakota Defective ABS?
  192. 2000 Dakota tail light trouble
  193. Manual hub conversion kits?
  194. Replacing fuel injectors
  195. 4.7 Lifter Noise
  196. Spongy Brakes
  197. 4x4. Working sometimes!!!!
  198. Need QUICK question answered
  199. bed liner - duplicolor bed armor?
  200. 2002 Dakota running at high RPM and shifting poorly
  201. Photoshop needed
  202. 2001 swap from v6 5 speed to v8 auto
  203. Front Main Seal
  204. Dodge Dakota Stalling?
  205. 2000 dakota odometer and speedometer not working?
  206. 01 dakota - just installed heater core, now weird electrical problems
  207. Kicker KS60's Stolen
  208. 02 dakota trans shift problem?
  209. replacement filters/valves/sensors
  210. Replaced CV Joint on front Propeller Shaft - pics
  211. Replica Hurst Pro Shifter!
  212. 2000 dodge dakota interior lights
  213. Removing the 7 & 8 coil packs
  214. Dieletric Grease, is it required?
  215. Fender Adjustment
  216. Starting, dying problems on 98 4 cyd
  217. 99 fenders rotting out
  218. anybody run a custom convertor?
  219. Pulls Left?
  220. PO 121 Code
  221. Truck won't start
  222. 2000 4.7 transmission issues
  223. 45rfe transmission question!!!
  224. Dogde Dakota 2002 4wd Sport
  225. I want a posi rear end
  226. 98 Dakota 5.2L No Spark
  227. Cylinder heads?
  228. Ticka-ticka-ticka sound on start up and metalic odor
  229. 02 Ball Joint replacment
  230. the 'no bus' issue
  231. 2000 quad cab tranny codes from car md????
  232. 02 4.7 interchangeable w/00 jeep 4.7???
  233. 03 Dakota block heater problem
  234. NV3500 Capacity
  235. Gas Tank Size
  236. Tires
  237. Exhaust parts
  238. Want to lift 2wd dakota..
  239. 99 dakota 5.2 tranny / front diff issues
  240. truck won't start, need help!
  241. Small squeaking sound from under the hood
  242. need radiator help
  243. Linkage to transfer case
  244. 97dakota completely redoin the engine
  245. Engine noise
  246. Torsion lift for new tires.
  247. wiring harness problem
  248. CEL flashes when tranny TRIES to shift into 4th
  249. 2001 Dakota overhead HUD console
  250. chrome window switch upgrade
