PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Brake Balance F-R
  2. Newbie question
  3. Is my Dakota lifted?
  4. A/C Upgrade with R410A?
  5. Update since replacing sensor... still need your help :)
  6. 4x4 Problem / Front Driver side tire squeak
  7. Best Plugs for 3.9L?
  8. Front brake issue
  9. newbie questions on 2003 Dakota QC SLT 4WD 4.7L
  10. Engine Shudders after Overheating
  11. 03 dodge dakota CTM issues
  12. 2003 4.7 thermostat.
  13. PA 3in body lift steering problem
  14. P0138, P0500, P0455 1998 dakota, 5 speed
  15. Remanufactured Cardone computer and no changes despite dealer flash
  16. New guy from Oregon
  17. Dakota gurus... help a newbie out
  18. Need some insight
  19. Help, gas leak
  20. 2000 dodge dakota SLT 2wd Parking brake
  21. 2001 Dakota trans issues
  22. 2000 dodge dakota transfer case grenaded
  23. Tires
  24. Front end rumble?
  25. Code 1762 test procedures on 2002 3.9 and ecu question
  26. 4x4 V8 Swap | Piecing 1 truck together from 2
  27. Idle Arms
  28. Running without radiator shroud
  29. code p0500
  30. high idle
  31. Fuel pump and P0456
  32. Towing a RV
  33. Electrical gremlins at their finest
  34. Vibrations, 98 dakota
  35. Blower motor. 98 Dakota
  36. 1999 Dakota caliper bolts stripping
  37. Used 2000 4.7 4x4 5spd Dakota
  38. Code 12
  39. 04 Dakota ac question
  40. Dual Exhaust.
  41. Alarm will not turn off
  42. Rack and pinion VS steering box
  43. Dakota miss fire help
  44. replace center seat with console
  45. Power Window Won't Go Up
  46. Valve stem seals leaking, need specs for magnum 5.2 V8
  47. Upper control arm bushings
  48. Transmission
  49. OBD plug, no power.
  50. Question: will fog lights from a Ram work in a Dakota?
  51. Passenger half axle
  52. Right turn signal problem
  53. Dakota key
  54. Torsion bar removal
  55. Lower ball joint
  56. Manual swap question
  57. new owner with questions
  58. blinking check engine light
  59. 1998 Dakota: Electrical havok: tail lights
  60. Oil pan
  61. No Bus
  62. Power windows issue 00 Dakota.
  63. Bad hub or what?
  64. TPS, 11% to 78%?
  65. What happens when you ignore the chain tap noise.
  66. 02 Dakota 4wd 4.7l rebuilt engine now it wouldn't start!!!
  67. First Truck!
  68. Potential Dodge newcomer...
  69. 231D transfer case
  70. Rough idle/p0305
  71. '01 Fuel Smell after sitting
  72. Leaf springs?
  73. Body kits
  74. stub shaft removal
  75. 2001 Dakota
  76. 99 Dak Rack and Pinion Bushing Install
  77. 2000 dakota in need of repairs
  78. no longer own a Dakota
  79. Looking for some help.
  80. Parts interchange 98 Dakota to 01 Durango
  81. Someone keeps breaking into my 1998 extra cab
  82. brake pedal hangs low
  83. 1999 Dodge Dakota V6 no start, help.
  84. Under dash, weird wiring found
  85. Rack and Pinion top shaft seal
  86. 1998 dakota just purchased
  87. Rear Axle Question.
  88. engine recommendations
  89. 1997 Dakota security
  90. Possibly another 02 problem
  91. NV3500 question
  92. 2000 dakota sport 2wd 3.9l rear axle and gearing 60mph 2k rpms
  93. project dakota motor swap
  94. 2000 dakota sport 2wd v6 vibration in park
  95. PCM question
  96. 2002 Dodge Dokota V6 loosing power, diagnosis? help?
  97. 3.9 to 5.2 swap
  98. 97 dakota 5.2 misfire
  99. Abs Light 78 base brake system incident.
  100. Front cab mount rust
  101. 2000 Dakota diff drop
  102. Misfire
  103. Misfire on same side of engine
  104. 2001 Dakota 4.7/4Wheel leaving me scratching my head...
  105. MAP Sensor wet!?
  106. Torsion Lift is bad?
  107. Can I heat shrink the O2 sensor connector
  108. 2001 Dakota 2.5 Bucking Issue
  109. Got a 2000 Dakota, could use some advice on the best way to black it out.
  110. Small MAP Sensor help needed
  111. No Tall Dakotas??
  112. No brake lights!! Help
  113. Simple O2 Sensor question
  114. P0108 and P0132 after a big shower
  115. The Haunting of a manual 4x4 2000 Dakota QuadCab in V8
  116. I need 12v at the back of the truck for an accessory which wire?
  117. power steering pump bolts
  118. steering rack replacement?
  119. Possible new owner ( questions :) )
  120. Engine light code p1196
  121. Help a mudding bud
  122. Wheel bearing? Strange noise
  123. Transmission question
  124. 4.7 Head Scratcher
  125. Stuttering dakota
  126. Help a green horn
  127. Starting the build process
  128. Where to buy?
  129. 2000 Dodge Dakota after market stereo problems
  130. building a drag truck.
  131. EVAP Big leak detected code P0455
  132. sludge in oil filler
  133. 2000 V6 Looking for a hand
  134. Best seat covers ?
  135. Help with audio components and wiring
  136. 2004 Dakota Quad Manual Window Regulator
  137. 1993 Dodge Dakota 15x6 Rims??? Trying to find
  138. Rattling on startup
  139. Misfires, cant speed after 20mph, Codes P1281 P0340 P0133 P1391
  140. Battery drain while truck is off
  141. HELP 3.9L v6 Dakota Power steering pump
  142. 4.7 engine don't always start on 1st key turn
  143. 3" lift with 33x12.50
  144. What's your tire pressure ?
  145. CTM replacement question
  146. Please help, Oil Everywhere
  147. Replacing windshiled molding
  148. 3.9L to 5.2 engine swap
  149. New project or 2 or 3?
  150. 4.7 Stalls on deceleration
  151. Dakota trim level 2nd gen
  152. Do all replacement O2 sensors have wires + plugs
  153. Upper control arm bushing
  154. '01 Dakota Radio Fit
  155. Hot problem
  156. Torsion bar question
  157. 99 Dakota/Durango 5.2 engine swap
  158. Oil pressure drops to zero then up again?
  159. Transfer Case swap
  160. odd noise
  161. Wiper motor pinout
  162. Your Experience With Spray On Bed Liner ?
  163. 1999 Dodge Dakota Sport Door Decals
  164. 5.2 Magnum stroker crank
  165. 2001 Dakota PCM fuse
  166. Diesel adapter, need 3.9L flywheel dimension
  167. Rear Differential Troubles
  168. Several problems, vacuum related???
  169. need a little help with a stroker build 5.2 magnum
  170. Random misfire. Can't find it
  171. flashing check engine light 2004 Dakota v-6
  172. Show me your exhaust tips.
  173. Do you have a,.....Performance Catalytic Converter ?
  174. 2000 Dakota club cab side vent window leak??!
  175. truck shaking
  176. Cruise control
  177. Truck cranks up at high rpm
  178. Keyless entry
  179. 99 Dakota 5.2l cluster flickering
  180. backfire ?
  181. A-T downshifting on hills
  182. It was time...
  183. Just bought a 2000 Dakota extend cab
  184. p0442
  185. My $400 Paint Job. (Monstaliner)
  186. 2000 2.5L Engine Codes
  187. Signal problem
  188. spark plug wires
  189. Battery cables
  190. Resetting the PCM
  191. Pinion Bearing
  192. Electrical Connector Won't Budge
  193. steering rack replacement?
  194. Tv cable
  195. Which brand vent-visors and type ?
  196. Will this radio fit?
  197. Which Brand of Exhaust and Type ?
  198. Various interior (dash type) lights on when off
  199. looking for a new pair of headlights.
  200. What is This Part? No Start Issue.
  201. Horn/alarm issue. Need advice please.
  202. '02 3.9 lost turn signals/flasher and brake lights -- relay?
  203. Hemi upgrade
  204. New Bumpers FINALLY 2WD
  205. Running Under Temperature. NEw Thermostats not fixing problem
  206. Three different mechanics couldn't fix it
  207. fog lights lenses cracked.
  208. gear shifter
  209. multiple misfires and transmission codes
  210. Clutch problem
  211. Highbeams mystery PLEASE HELP
  212. No Power When Gas Given
  213. Air sucking noise / gurgling noise from engine bay
  214. 4.7 Random Long-term Misfire Mystery
  215. it's the remote starters fault
  216. New to this, engine flutters
  217. 4.7 engine lifting fixture
  218. Need help with heater getting frustrated
  219. Pulling to the left
  220. Brake Problems
  221. Rear Window issue
  222. Battery hold down bolt stuck.
  223. 04 Instrument Panel Bulb Replacement
  224. cooling system question
  225. 98 2wd DAKOTA 42RE Third Gear issues
  226. Ram Borla dual tailpipe on 01 Dakota
  227. 2001 Dakota no brake lights
  228. LED light bar for 2001 4 westin safari bar
  229. Instrument cluster swap
  230. 2001 dodge dakota exhaust in cabin problems
  231. Seat Swap?
  232. Will map sensor readout be off if plenum gasket is blown?
  233. p432 code
  234. Engine compatibility question, 2004 3.7L
  235. hard starting when warm
  236. Need your oppinion on Truck sale Value
  237. Towing
  238. Head gasket failed chemical test - options?
  239. Which actuator motor? air our floor vent problem.
  240. High Idle upon Startup ??
  241. Piston Damage Question
  242. Steering Leak Question
  243. Radiator inlet and outlet sizes
  244. Starter dakota 99 or ignition switch
  245. Coolant reservoir leaking at lower seam, can it be patched?
  246. oil consumption
  247. Anybody ever seen this style hood before?
  248. running rough
  249. Code Question
  250. 3.9 air cleaner assembly
